01-14-2011, 04:23 AM
Giana Giana is offline
Hello,
I have some VHS tapes, Formula 1, I want to digitize dvd.
U.S. Grand Prix 2001 -> EP VHS (PAL) 2.00Hours
REC with JVC dr-m10 in FR 1:55??
REC with JVC dr-m10 in FR 180/FR175??
1) What is the best quality?
2) Explain better FR Mode
3) I always FR180 use of this possibility?
01-14-2011, 04:36 AM
Grand Prix implies fast action (movement of camera work, not the cars). And that, in turn, requires high bitrate to avoid block artifacts.
Option A:
If you want to break it up across a pair of 1-hour DVDs, that would work well. Use XP mode.
Option B:
However, if you do not want to break up the content across spanning discs, then go for the 352x576 with the highest available bitrate. FR170 is always safely in the 352x576 + good bitrate range, and that runs just shy of 3 hours. Use FR170 mode.
And if you're interested....
Technical Notes:
The switchover from 720x576 to 352x576 varies slightly from model to model. On my NTSC JVC DR-M100 recorder, that happens at either FR160 or FR165. I forget exactly -- really need to make myself a note card.
If you want to spend some time testing the exact perfect settings, record a quick segment at everything from FR150 to FR170 on a DVD-RW. Finalize, then put in the computer, and use Gspot to see what's what.
You NEVER want to use 720x576 beyond 2 hours (120 minutes, FR120, SP mode), and even 2 hours is pushing what's acceptable. Remember that most pre-HD broadcasts, as well as most consumer recording formats (like VHS) were closer to 352x576 (or 352x480 for NTSC) than they were to the Full D1 specs. Related topic: Is SP MODE the Best DVD Recorder Mode? (NO!)
Hope that answers you.
01-14-2011, 07:10 AM
OK
Gspot, JVC dr-m10 PAL
FR 150->720x576
FR 155->352X576
FR 160->352x576
FR 165->352x576
FR 170->352x576
FR 175->352X576
FR 180->352x576
FR185-> 352x576
FR 120->720x576
01-14-2011, 11:31 AM
Gp F1 usa 2001
DVDr JVC DR-m10
1)FR150->720x576-> Kbps 3837
2)FR155->352x576-> Kbps 3320 The best?
3)FR160->352x576-> Kbps 3239
4)FR165->352x576-> Kbps 3118
5)FR170->352x576-> Kbps 3029
6)FR175->352x576-> Kbps 2960
7)FR180->352x576-> Kbps 2822
8)FR185->352x576-> Kbps 2759
1*FR120->720x576-> Kbps 4610
01-14-2011, 11:36 AM
Yes, that would be the next-best setting to XP mode. You've got it.
Remember the LSI based JVC encoders are all using single-pass VBR, the best live MPEG encoding method.
The FR155 mode from above shows a 3.3Mbps stated avg, and I believe it has 8.0Mbps max bitrate.
Realistically, viewed in a bit rate viewer, I think it spikes around 4.0 to 5.0Mbps max.
And the actual average bitrate may be a tad higher, too. I think the flags/settings are conservative.
Minimum is whatever is needed by the encoder.
01-14-2011, 12:01 PM
The best quality VHS is
Ntsc FR 180
PAL FR 155-> kbps 3326 is OK?
01-14-2011, 12:08 PM
Ntsc FR 180
Yes.
FR180 is good.
FR155 is better.
FR125-FR150 is bad
FR190+ is bad
01-14-2011, 12:28 PM
Thanks thanks lORDSMURF/ ADMIN
JVC FOREVER
Video advice from lordsmurf? Where to find me vs. fake lordsmurfs online! lordsmurf General Discussion 6 05-07-2021 08:56 PM
Is SP MODE the Best DVD Recorder Mode? (NO!) lordsmurf Capture, Record, Transfer 4 04-14-2013 10:01 PM
Panasonic FR mode or samsung 4 hr mode for vhs to dvd cyber-junkie Restore, Filter, Improve Quality 5 02-24-2010 10:29 PM
Encoding an XP (1 Hour Mode) MPEG to SP Mode shadowkaos Encode, Convert for discs 2 10-30-2007 09:29 AM
The lordsmurf method using DVD recorders lordsmurf Capture, Record, Transfer 0 02-13-2004 12:16 AM
