01-17-2023, 10:54 PM
endoskeleton endoskeleton is offline
My current conversion/capture setup is VCR Component > PVR Component and it works well. But I am eager to 'upgrade' to VCR S-Video > PVR S-Video if possible.
I am not and do not want to use my PC, so not looking for Capture devices/setups involving a PC.
I've been looking for PVR models with S-Video input, but am having difficulty finding any. The closest models I found have either Composite and Component, but no S-Video?
I've tried looking into DVD with/HDD combos, but my findings seem to indicate that you can't access and transfer files from that HDD to the PC. (Short of ripping out the HDD from the player itself).
If PVRs aren't possible, I dread the thought of recording the DVD and then copying that DVD onto my PC...
Thanks in advance.
01-18-2023, 02:31 AM
PVR's will record with compression and no image stabilization, They are not any better than a Chinese ClearClick video recorder to SD card.
01-20-2023, 07:01 AM
KhAoS182 KhAoS182 is offline
I prefer a DVD recorder over this device...
01-20-2023, 03:36 PM
Eric-Jan Eric-Jan is offline
Thanks in advance.
You really mean "component" ? because… if this works, why should you want to go further with s-video ?
there's not much difference between them…. most cheap PVR's convert to h.264, the more expensive ones, also support ProRes or another editable format.
Further more you don't exactly mention what you are using, which doesn't give much clues to help you any further, if you want to do better than this expect to spend some money, otherwise send your analog media to a service that will do it for you.
btw. good source material will playback fine from DVD, VHS was never designed to be watched on a big screen….
01-21-2023, 12:39 AM
He means by component, composite yellow, and red & white for audio, It's often wrongly named by newbies as component because component use RCA connector too but in Red/Green/Blue.
01-21-2023, 03:05 AM
But with a bit of effort and an average-to-good quality tape, it comes out great on a big TV.
01-21-2023, 04:27 AM
Yes, that's what i mean, it's not that bad as some people say, also because a lot of lcd/oled tv's have bad composite decoding, putting it on DVD improves picture quality in that case, i noticed that on my Sony Bravia tv.
That's why the OP should give more detailed information, so we can leave out the guess-work, (hint for OP)
02-12-2023, 05:37 AM
OP disappeared?
Just saw this thread still open in a tab, half typed response. May as well finish and submit...
Biggest quality gains come from quality VCR, ie JVC/Panasonic S-VHS VCR with line TBC.
What, exactly, are you referring to here?
Literally anything is better than the ClearClick (earned nickname = ClearCrap or CrapClick), even the awful Easycap (Easycrap) is better. Yeah, it's just that awful.
Yes.
Originally Posted by Eric-Jan View Post
Sony Bravia tv.
I still have a Bravia. It was a game changer in the late 2000s, as the filters on the HDTV made the image look better than the source. Many TVs still lack the post processing filters, but Sony was first to market with them, from what I remember. I won't get a set with post processing.
pvr, s-video
ATI 600 USB video input not working? bitripper Capture, Record, Transfer 4 10-25-2022 10:29 AM
How to enable s-video input on Pinnacle 510-USB? ELinder Capture, Record, Transfer 40 02-01-2020 03:20 PM
Audio signal as video input? renzooh Capture, Record, Transfer 5 08-27-2019 02:48 PM
Any good video input selector hardware for CAPTURE? nicholasserra Capture, Record, Transfer 1 12-18-2018 06:00 PM
Diamond ATI 600 PCIe black/green screen video input? dad2 Capture, Record, Transfer 1 02-12-2018 06:38 AM
