07-20-2017, 04:05 AM
DeejayProductions DeejayProductions is offline
Hi there
I have a Hi8 PAL transfer job to do and am trying to identify the issue with this footage/tape. I am capturing from a Sony Handycam Video8 T420E via Dazzle DC100 although I am having no other issues capturing from and with these devices. Can anyone help? This is an issue with 2 out of 15 tapes a customer has sent me. The others are fine. Maybe these 2 were filmed on another camera or seomthing? Any ideas?
Cheers
Dave
07-21-2017, 04:31 AM
I can't remember the origin of these defects (tape or vcr but likely both) but i remember Jmac on doom9 had a solution for that with his multiple captures technique. You'd need avisynth and some free time...
check here to begin
http://forum.videohelp.com/threads/3...=1#post2122313
What you could try before all that, is disengage the automatic tracking of you vcr and go manual to see if that gives you a more stable signal. Also try to change the audio track stereo > mono if available
The following users thank themaster1 for this useful post: DeejayProductions (07-29-2017)
07-21-2017, 06:54 AM
juhok juhok is offline
That's pretty bad. It's dirty/worn out heads with either at record or at playback stage. Bad quality / badly stored tape with the metal coming off of the surface would also do this on playback. But if after playing this tape the next one is good without cleaning the video heads I would guess it's a problem at the recording stage and not playback. If it's recorded = burned in = deterministic -> there's no help from multiple captures. If it's problem on playback, multiple captures could help.
Here's a sample of a video I did for a customer with badly damaged tape (wrinkles, scratches). 5 captures and median with avisynth.
The following users thank juhok for this useful post: DeejayProductions (08-21-2017)
hi 8 footage, pal
Lines in captured VHS footage? skycaptain09 Restore, Filter, Improve Quality 7 03-28-2017 09:57 PM
Find how many hours of footage in Mac Finder? BayAreaSean General Discussion 3 04-23-2016 07:04 PM
Problems with ingesting Hi-8 footage rsvstudios Videography: Cameras, TVs and Players 3 07-22-2015 09:58 AM
VHS footage restore Advice using VirtualDub/Avisynth Zoink187 Restore, Filter, Improve Quality 0 03-28-2014 09:14 PM
Problem importing VHS NES and SNES footage gameboybob1985 Capture, Record, Transfer 2 04-01-2012 09:21 AM
