07-02-2018, 08:08 AM
buchsderbaum buchsderbaum is offline
Hi,
I just realized that it is possible to capture directly to FFV1 with VirtualDub. But it only delivers files in an AVI container.
Does anyone know how to capture in a Matroska container (mkv)?
Thanks in advance!
Best regards,
Buchsderbaum
07-04-2018, 03:45 PM
Virtualdub can only capture to AVI. (Couldn't find the relevant issue on the bug tracker.)
It's possible to capture to .mkv (and a host of other formats) using ffmpeg. I have no idea how well it works though.
ffv1, matroska, mkv, virtualdub
Best VHS and Umatic capture workflow with VirtualDub to FFV1? JohnR2 Capture, Record, Transfer 10 03-20-2018 07:22 PM
JVC HM-DH40000U firewire output directly to computer? Jazzspot Capture, Record, Transfer 21 06-09-2017 08:39 AM
Any way to capture ATSC/QAM stream directly? premiumcapture Capture, Record, Transfer 7 08-24-2014 09:05 AM
Convert audio cassettes directly to CD's, without computer? admin Encode, Convert for discs 0 09-04-2010 10:04 AM
Capture DIRECTLY to DVD-R JimGorsline Capture, Record, Transfer 2 07-08-2004 11:23 PM
