05-06-2024, 08:28 PM
It's equivialent to whatever "auto" changes to on the JVCs if "B.E.S.T" is turned off.
There is not really a best setting as such, it's up to preference - use edit/distinct if you want the least processing, normal/auto if you want a bit more noise reduction though it can over-smoothen things in some cases. Though I've found the TBC/DNR equipped JVC/Philips vcrs to cause ghosting between frames on the luma channels even when the TBC/DNR function is off and can also cause clipping in some cases so there is some tradeoff with these.
The following users thank hodgey for this useful post: Kazuya (05-06-2024)
capture card, dvd recorder, tbc
Picked up some PCI capture cards! waloshin Capture, Record, Transfer 2 03-24-2017 09:37 PM
Comparing capture setups for XCapture-1 cerestan Capture, Record, Transfer 15 11-05-2016 08:12 AM
ATI capture cards - AGP vs. PCI vs. PCI-E? SinghDk Capture, Record, Transfer 5 04-06-2015 10:05 AM
Do ATI All In Wonder cards or ATI TV 600/650 cards capture both PAL and NTSC video? kpmedia Capture, Record, Transfer 0 06-16-2011 05:44 PM
CD/DVD Care and Handling Guide from NIST/ITL kpmedia Blank Media 0 11-21-2010 12:41 PM
