02-05-2023, 04:53 PM
When it comes to Mac I'm like an idiot in a control room, Have no clue what was/is out there, Being a PC guy my entire life, Anyway what latptops or Mac minis should I get and what version of iOS that works with Aja's software?
I found this handy link about Mac devices that have firewire.
02-05-2023, 05:32 PM
if you look at the link i did post there you can see what Macbook pro's can run Snow Leopard 10.6.8
if i did read right then Macbook Pro's from 2006 to 2011 can run Snow Leopard 10.6.8
Mac Mini from 2006 to 2010 can run Snow Leopard 10.6.8
two example
https://www.macupgrades.co.uk/store/mac/MC375LL-A#ram
https://www.macupgrades.co.uk/store/mac/MC724LL-A#cab
and if it does not have firewire but it has thunderbolt then you need this adapter
Apple Thunderbolt to FireWire Adapter and Firewire 800 to Firewire 400 adapter
02-05-2023, 08:11 PM
Why the requirement for Snow Leopard 10.6.8? Is it Aja software or something else? Is this the DVD I need?
02-06-2023, 05:13 AM
i can not be 100% sure if that Install DVD works or not but i think so  but that one does not work on Mac Pro 5.1 it needs a special version
Mac Pro 5.1 is a desktop computer not a Laptop
here is the Latest Drivers for Aja IO LA and it say Snow Leopard
https://www.aja.com/support/item/512
02-06-2023, 10:21 AM
I'm thinking about a Mac mini with firewire 400 now, They are small, All what's needed is a monitor, Keyboard and a mouse which any Mac guy should have anyway.
02-06-2023, 11:15 AM
yes and Mac mini is cheaper then the other models i think
here was more driver and software stuff to the Aja IO LA
https://www.aja.com/support/legacy/io
02-06-2023, 01:07 PM
maybe you need Superdrive USB 2.0 Part Number: MD564ZM/A
to boot the Install DVD on a Mac Mini i'm not sure if regular PC usb DVD drive can boot
or you can create boot usb memory stick of the dvd i think not 100%
SuperDrive look like this
02-06-2023, 03:49 PM
I will get the one with built in DVD drive like this one.
02-06-2023, 04:25 PM
ok looks good
02-08-2023, 04:16 PM
Hi it looks like Aja IO LA works also on OSX Mountain Lion 10.8.5
but only with the latest ProIO_ControlPanel_v1.2 that also give you the new Firmware version 5.8 to the AJA IO LA
and driver version AJA_Io_v3.1 and the Capture software AJA_VTR_Xchangev4
so all those 3 files you need to get AJA IO LA to work
one more thing you need also for AJA_VTR_Xchangev4 to work and recognise AJA IO LA is to copy QT .component files to
Library/Quicktime/ folder
here is the guide how to do it and the files https://studioartist.ning.com/forum/...mac-if-you-don
the QT .component files look like this in the picture "Appel_Prores_codec.png" that you copy to the Library/Quicktime/ folder
otherwise you have to install Final Cut to get AJA_VTR_Xchangev4 to work
02-12-2023, 11:46 AM
Hi here is the right pinout and Input and Output of AJA IO LA Audio Cable
and a picture of my own DIY AJA IO LA Cable
02-12-2023, 12:06 PM
it's possible to use AJA IO LA as stand-alone unit like a some kind of TBC
but you need ProIO_ControlPanel_v1.2 to change setting if needed then you can disconnect it from the computer and use it like a some kind of stand-alone TBC pass-thru
The following users thank jjdd for this useful post:
srmusico (03-25-2023)
03-25-2023, 02:44 PM
Hi guys! I have also a working unit of AJA IO Firewire (NOT "LA" model)
I have been looking how to get it working right and how it works in different systems.
Actually I have it working perfectly in Mac OsX Mavericks 10.9.5 , also working in Mountain Lion, Lion, Leopard and Snow Leopard .
Does this AJA have TBC features?
I have other AJA capture cards, Black Magic and Matrox cards. The most "stable" capture card is my Matrox MXO2 LE MAX.
My AJA IO and AJA Kona LHi needs a really stable input signal. If not, there are dropframes. I use a DMR ES10 to get "fixed" my signal in my AJA Captures.
As soon as i can, i would create a complete post comparing how these capture cards (and some more like Pinnacle 510) works with the same VCR input.
11-03-2023, 03:26 PM
@jjdd et al.,
Can a Tascam pin-out DB25 to XLR cable/snake be used with the AJA Io LA by renaming the Tascam XLR connectors to match the AJA DB25 pin-out you posted (e.g., relabel Tascam Channel 1 Output XLR to AJA Channel 1 Input XLR)? Or if I attempt to cobble my own adapter, since for VHS I'll only use one or 2 audio channels, can I wire just two XLRs to a DB25 connector? Or will you sell me a cable? (Noob, I don't know how to PM or transact.)
I'm assembling:
JVC HR-S9600U -[S-Video]-> AJA Io LA -[Firewire]-> iMac 9,1 (2009 with SSD; maybe OSX 10.8.5 you proved in!)
[RCA]-> Rolls MB15 -[XLR->DB25?]
The other items have arrived or are on order, the XLR-DB25 cable is the last missing piece before I connect everything and find software glitches and which hardware doesn't work right (probably eBay JVC VCR?)...
(BTW, my "new" mac is a 2015 MacBook Pro with replaced battery and SSD upgraded to 2TB. I'll eventually have to upgrade, but I'm averse to SoC designs where any hardware failure turns it into trash...)
| Thread |
Best container to capture Mini-DV via FireWire?
ehbowen |
31 |
09-19-2018 06:25 AM |
Any way to transfer HD Mini DV using Mini DV camcorder?
waloshin |
4 |
08-31-2016 05:24 AM |
Mini DV Capture Errors found using DVAnalyzer
JRingo |
1 |
06-03-2016 09:18 AM |
Mini DV capture using Pinnacle Studio Moviebox in Windows 8?
StickManMax |
6 |
06-20-2015 09:42 AM |
Capture mini DV tapes with broken sound
agios59 |
3 |
03-28-2010 04:37 PM |
