11-15-2020, 12:56 PM
waloshin waloshin is offline
Premiere pro NTSC-VHS, HI8 ... are they upper field or lower field first when editing and exporting for DVD?
11-16-2020, 10:18 AM
JPMedia JPMedia is offline
I am curious to hear what other users have to say on this issue. I find exporting MPEG-2 video from Premiere Pro as "interlaced" results in what appears as stuttering frames. My current workaround is to export MPEG-2 video as "progressive" but I am not certain if this setting interferes with image quality
11-16-2020, 11:07 AM
There is a setting for what field order to export in in adome media encoder. You do have to make sure premiere knows what field order the source material is in though, the commonly used lossless video formats (huffyuv, lagarith, utvideo) don't have any way of letting an application know. If you are dealing with DV or mpeg2-encoded material, premiere should recognize it automatcially as long as the files are encoded correctly.
You do not want to save interlaced material as progressive in a lossy format like mpeg2, that will certainly create artifacts.
The following users thank hodgey for this useful post: JPMedia (11-17-2020)
11-16-2020, 06:41 PM
You are right Premiere pro is horrible at knowing what field order the files are. I always make sure to interpret the footage now.
11-17-2020, 06:07 AM
Fields are determined by the capture card. And 99%+ of the time, DV=bottom (BFF), everything else is top (TFF).
Lossless AVI has no field flags. It must always be manually set. But even MPEG, MXF, and others must be verified when the project is created.
(The "fun times" begin when you have mixed-interlace sources, transport streams, TS. But that generally only happens when you directly download a broadcast stream, or work in the broadcast field. Been there, done that, hated those projects.)
Premiere is fine, not at fault.
Exporting uses MainConcept SDK. If you use something else on export, I've seen issues, experience issues in past years myself with 3rd-party encoder plugins.
ATI AIW card: lower of upper field interlace? Mejnour Capture, Record, Transfer 4 12-13-2017 01:14 PM
FS: New upper drum VEH0467 for Panasonic FS90/FS200/V8000 [ENDED] juhok Marketplace 1 08-12-2017 04:49 PM
Super black and white pixels / lines in lower field (only) of VHS capture ctrl-z Restore, Filter, Improve Quality 11 07-26-2015 03:23 PM
Trouble with Premiere Elements widescreen interlace field order - TFF or BFF? GreenAcres Edit Video, Audio 4 07-25-2014 07:40 AM
Field Dominance / Field Order (Top or Bottom) deter Encode, Convert for discs 1 12-18-2011 10:35 PM
