06-16-2024, 06:21 PM
andrewprjnn1 andrewprjnn1 is offline
Got a report from a client indicating that their deliverables are not playing on their TV. Only information I was able to obtain was their TV is a "Sony Bravia 4K UR2", of which, I am having a very hard time finding information on online. Sony has always been very strange with their TV models and the UR2 seems to fall under an umbrella of different Sony 4K TVs.
The encoded files I made have been tested and confirmed to play through different Blu-ray players, smart TVs, Mac, PC, Android and Apple iPhones, but this model they have has me dumbfounded.
I've heard that some smart TVs are counterintuitive and act as "dumb" TVs in the context of USB playback, but not sure which those are unfortunately. Anyone have any suggestions for proper encoding to play on newer Sony TVs? Particularly those with Android TV and Google TV?
MediaInfo below for one of the files:
General
Complete name                            : 1_VHS.mp4
Format                                   : MPEG-4
Format profile                           : QuickTime
Codec ID                                 : qt   0000.02 (qt  )
File size                                : 3.97 GiB
Duration                                 : 2 h 3 min
Overall bit rate                         : 4 620 kb/s
Frame rate                               : 59.940 FPS
Encoded date                             : 2024-06-09 19:29:11 UTC
Tagged date                              : 2024-06-09 19:29:11 UTC
Writing application                      : Blackmagic Design DaVinci Resolve
Video
Format                                   : AVC
Format/Info                              : Advanced Video Codec
Format profile                           : High@L3.1
Format settings                          : CABAC / 10 Ref Frames
Format settings, CABAC                   : Yes
Format settings, Reference frames        : 10 frames
Format settings, GOP                     : M=1, N=15
Codec ID                                 : avc1
Codec ID/Info                            : Advanced Video Coding
Bit rate                                 : 4 552 kb/s
Width                                    : 702 pixels
Height                                   : 472 pixels
Display aspect ratio                     : 3:2
Frame rate mode                          : Constant
Frame rate                               : 59.940 (60000/1001) FPS
Color space                              : YUV
Chroma subsampling                       : 4:2:0
Bit depth                                : 8 bits
Scan type                                : Progressive
Bits/(Pixel*Frame)                       : 0.229
Stream size                              : 3.91 GiB (99%)
Color range                              : Limited
Color primaries                          : BT.709
Transfer characteristics                 : BT.709
Matrix coefficients                      : BT.601
Codec configuration box                  : avcC
Audio
Format                                   : AAC LC
Format/Info                              : Advanced Audio Codec Low Complexity
Codec ID                                 : 2 / 40 / mp4a-40-2
Bit rate mode                            : Constant
Bit rate                                 : 64.0 kb/s
Channel(s)                               : 2 channels
Channel layout                           : L R
Sampling rate                            : 48.0 kHz
Frame rate                               : 46.875 FPS (1024 SPF)
Compression mode                         : Lossy
Stream size                              : 56.4 MiB (1%)
Default                                  : Yes
Alternate group                          : 1
Other
Type                                     : Time code
Format                                   : QuickTime TC
Time code of first frame                 : 01:00:00:00
Time code of last frame                  : 03:02:59:26
Time code, stripped                      : Yes
Language                                 : English
Default                                  : No
06-16-2024, 07:49 PM
I wonder if it won't play because of the:
-Non-standard frame size. If it's ex-NTSC VHS, a normal frame would be 720x480 4:3, or 640x480 4:3.
-Colour: SD colour is, I understand, BT.601. BT 709 is for HD (720 or above).
06-26-2024, 06:14 PM
Correct.
Install the VLC app, use it.
encode, encoding, sony
Sony DCR-TRV460 not playing back analog 8mm tapes? Danfun64 Video Hardware Repair 4 09-03-2022 11:16 AM
Sony SL-F1 Betamax stops playing after 2 seconds? TONYFRANCE Video Hardware Repair 1 06-25-2018 11:38 AM
Sony DCR-TRV330(PAL) no image/sound when playing tapes? hodgey Video Hardware Repair 4 02-12-2018 11:22 AM
Best camera for playing 8mm videos? (Sony Video8/Hi8 formats) tomr Capture, Record, Transfer 17 03-22-2012 09:06 PM
MPEG not playing on Premiere 6.5 - jittering video no audio morsagmon Edit Video, Audio 1 04-18-2011 07:59 AM
