04-22-2016, 12:58 PM
BayAreaSean BayAreaSean is offline
I'm using Adobe Premiere 5 and have ten 5 minute AVI clips that I've imported and edited individually on the timeline. I want to export each video file one by one to its on file using AME. So I'm trying to find away to select the whole timeline and export all the files at once but get separate files for each clip? Is this possible? i'm thinking it is but can't find out how. I know I can export each file one by one, but b/c I'll be working with 30-50 more of these clips I would rather find a quicker way.
04-22-2016, 10:59 PM
Premiere 5, or Premiere CS5.
Because 5 is from the later 90s, and is mostly useless. CS5 is from about 2012, and works well.
Assuming CS5, since you mention AME (Adobe Media Encoder), then you probably just need to select and deselect tracks. Deselect unwanted tracks, export. It will only export selected tracks. Repeat as needed. Make sense?
04-23-2016, 11:26 AM
Thanks for the reply but what I want to do is export all the separate clips within the timeline as individual files instead of having to export each file one by one, or export the entire timeline as one file. Ive attached screenshots of the export screen.
04-23-2016, 06:36 PM
That's not the intention of Premiere, so I doubt it will "export all" as clips. I think FCP has this function, but I've never used it -- and no idea what version that may or may not have it.
adobe premiere pro, ame, exporting avi
Adobe Premiere Version Validation sirbyron Edit Video, Audio 3 03-02-2015 08:19 PM
Is there an alternative to Adobe Premiere? rappy Edit Video, Audio 1 12-27-2011 12:31 PM
Help with Adobe Premiere and Huffyuv Files jrodefeld Edit Video, Audio 2 12-04-2011 01:50 PM
Adobe Premiere 6.5 Timeline Export Extremely Slow... SSStudio Edit Video, Audio 31 12-02-2009 02:19 PM
