12-27-2009, 01:39 PM
Downloads
Because these have become harder to find, I've attached them here to this post.
Full Versions Available
Please note that these DO NOT HAVE SERIAL NUMBERS and will run in demo/trial mode only. The trials are limited to 15-30 days. If you like the software -- and I'm sure you will! -- these can be bought for very low cost from Womble.
Order them here:
MVW Notes
Quick notes about Womble MPEG Video Wizard DVD vs non-DVD:
  • DVD: The benefit of the DVD version is that it encodes AC3, if you need/want AC3. I would not use it to author DVDs, it's not very good at authoring.
  • non-DVD: This version will only "stream copy" existing AC3 audio. Therefore, you can't add effects or re-encode it to a new AC3 -- you can only output to an MP2 or WAV. The non-DVD version encodes MP2 and WAV only. If you're just cutting out commercials or removing footage, then it will stream copy the AC3, re-encoding of audio is not necessary.
Need A Guide or Tutorial?
There are two great guides on this site, for using Womble MPEG-VCR and Womble MPEG Video Wizard.
Trouble?
If you have any trouble, feel free to join the forum as a Free Member (it's free!) and then ask in a reply to this post. Or better yet, after signing up, upgrade to a Premium Member, for the best in one-on-one support for your video project.
If you're not sure what to do with these ZIP or RAR files, then read this help post.
The following users thank lordsmurf for this useful post: ralph65 (10-22-2016)
Editing with Womble MPEG Video Wizard [VIDEO GUIDE] admin Edit Video, Audio 12 03-05-2009 10:39 AM
Womble Mpeg-Vcr problem-HELP!!!! MagnificentMarcus Edit Video, Audio 12 03-09-2008 04:44 AM
Which is better Mpeg-VCR or Video Redo? MagnificentMarcus Edit Video, Audio 6 10-14-2006 05:39 AM
Using VirtualDub for editing MPEG video admin Edit Video, Audio 0 11-16-2005 04:20 AM
Audio editing using Womble MPEG Video Wiz jrnyhead Encode, Convert for discs 3 02-08-2004 12:40 PM
