01-24-2020, 11:31 AM
SinghDk SinghDk is offline
Hi all,
Basically I've captured most of my videos now, yet I'm thinking what's the next step? I captured in HuffyUV, and looking at the files they are very large, and as VHS tended to be(30-90gb), there a lot of different scenes/events.
Question:
  1. Should I perhaps break up the old files first into small files/scenes/events?
  2. And if I use the virtualdub directstream, I assume it's a 1-1 copy with no degradation of quality?
  3. Is there a better way than virtualdub directstream if I just want to split up, but not degrade quality?
  4. What should I do about the videos where I just want the basic restoration, and then put them into my personal plex library for viewing? Which encoding would be best suited and which program to use(Money not a issue)
I am thinking I keep the orginal small clip files, trim what's not needed and after that I can start looking at restoration of videos.
The following users thank SinghDk for this useful post: Amanjm (01-24-2020)
01-24-2020, 12:25 PM
1. Yes, I would.
2. Yes.
3. No.
4. Plex assumes H.264, and I'd use Hybrid. Deinterlace may be required, testing needed. You'll probably want to resize the video from 720x480 to 640x480 (NTSC, right?)
01-24-2020, 01:42 PM
4) No, PAL - Live in Denmark.
Is there some basic restoration that's always needed that can run somewhat automated, or is that usually a bad idea?
01-24-2020, 01:54 PM
PAL 4x3 resize for interlace would be 768x576. You cannot resize the x480/x576 value, or it will break interlace.
PAL resize for deinterlaced is better as 720x540.
NTSC still 640x480.
All video tapes have
- chroma noise - fixed with line TBC in VCR, LSI chipset (for DVD recorders), Camcorder Color Denoise (CCD) filter in VirtualDub (for captures)
- overscan noise - mask with black, 2-pixel increments, and it re-centers remaining image
- grain - generally only a mild NR is used, so as low value Temporal Smoother (VirtualDub)
That ignores all color issues, which all homemade camcorder tapes tend to have.
Captured PAL VHS - Outputting to DVD - What Resolution Should I use? BayAreaSean Encode, Convert for discs 4 04-29-2016 11:13 AM
Mistakenly captured into MS-YUV 16 bit metaleonid Restore, Filter, Improve Quality 6 01-27-2015 03:46 PM
Codec to archive VHS captured videos with VirtualDub? knumag Encode, Convert for discs 2 07-21-2014 03:11 PM
No Audio Captured yargellham Capture, Record, Transfer 7 01-11-2005 01:53 PM
ATI video captured ... now what ? bigroy Capture, Record, Transfer 1 04-28-2004 03:52 AM
