03-16-2021, 11:49 PM
DukeRoyal DukeRoyal is offline
Hey there!
I have an AG-1980 -> TBC-1000 (also have aDMR-ES10, which didn't seem to help this problem on the first pass, so I ditched it for the second).
I'm getting a lot of noise on my playback and capture. My heads aren't the problem. I've had perfectly crisp pictures from newer tapes very recently. However, I acquired some former rentals and they have some artifacts. I would love to know how to clean them up. I need to learn this.
I'm struggling. I've spent hours trying to figure out what to do, and I feel more confused than when I started. I have Adobe AE, Virtaldub2, and AVI Synth capabilities. Any suggestions would be greatly appreciated.
Attached is a clip. Let me know if you need more info. Thank you so much in advance
03-17-2021, 08:28 AM
lollo2 lollo2 is offline
Have a look at the scripts in this post, they may help (or search "remove comets avisynth")
http://www.digitalfaq.com/forum/vide...th-script.html
03-17-2021, 02:44 PM
thank you! I'll take a look.
03-19-2021, 09:18 AM
You video sample is all glitchy
VHS software to split, remove noise, convert to H.264? Amanjm Encode, Convert for discs 1 01-30-2020 08:04 PM
Best filter to remove white snow noise? dima Restore, Filter, Improve Quality 1 01-22-2020 11:01 AM
Black streaks on S-VHS tapes? Demodulation noise/bearding? hodgey Video Hardware Repair 1 12-09-2018 02:00 PM
Can't remove video noise/artifacting (grain in dark areas?)) DeeSeven Restore, Filter, Improve Quality 8 07-23-2014 08:19 AM
How do I remove this noise from my capture? CyborgHyena Restore, Filter, Improve Quality 4 02-07-2013 06:05 AM
