06-05-2022, 10:13 AM
DG1965 DG1965 is offline
I would be grateful if anyone could please tell me if this screenshot is the correct setting on the Avisynth install. Choose Component>Select Association. Or should the "Add Avisynth Script to New Items menu" box be ticked?
06-05-2022, 01:48 PM
lollo2 lollo2 is offline
Do whatever you prefer, not important. I normally use notepad to open avs files for editing. For playng you can also use WMP, and thus the proposed association. You can always change the settings later
The following users thank lollo2 for this useful post: DG1965 (06-05-2022)
06-05-2022, 02:33 PM
Thanks lollo2. Yes I am going to use notepad. I will leave "Add Avisynth Script to New Items menu" box be unticked.
How to apply filter on select frame numbers in AvsPmod? kondwanii Restore, Filter, Improve Quality 2 05-14-2022 06:57 AM
Select range and offset audio to maintain a/v sync in Virtualdub? rprilenski Restore, Filter, Improve Quality 1 10-15-2021 09:56 AM
Advantages of Avisynth vs. Avisynth+ (plus)? homefire Restore, Filter, Improve Quality 4 07-02-2019 06:54 PM
Avisynth MT or Avisynth ST? WhatACuck Restore, Filter, Improve Quality 2 05-07-2019 02:17 PM
Help figuring out AviSynth Select structure? stevevid Restore, Filter, Improve Quality 0 09-17-2018 01:50 AM
