05-07-2023, 10:34 AM
S_Clayton S_Clayton is offline
I'm converting my family's VHS tapes to digital. I've successfully transferred over 50 recordings using various hardware (OBS,Premier Pro, and Photoshop) to correct the color and deinterlacing but this one recording is driving me crazy. It is not the tape because other recordings on this same tape are fine. I've tried the common methods to correct but nothing helps. I've added three attachments to my post. 1. Problem Child 2. Clip from same tape taken on a different day but recording the same ball field. 3. 2nd Clip after running through OBS deinterlaced to Yadif 2x, increased FPS to 60 and added a color correct filter, Im just a beginner and your input would greatly be appreciated.
File Type: mp4 1988 League Play part 1 - Trim - Trim.mp4 (23.63 MB, 10 downloads)
05-07-2023, 03:39 PM
In the first clip the levels are overblown, it really needs a recapture.
The following users thank latreche34 for this useful post: S_Clayton (05-07-2023)
05-07-2023, 04:35 PM
Thank you for looking my posted. Start of game as been recaptured.
05-07-2023, 06:52 PM
Still overblown, Try to use histograms in vdub.
05-07-2023, 07:33 PM
You need to lower the brightness and contrast for the capture. What program are you using for capture? Then we can give you some pointers.
The following users thank Hushpower for this useful post: S_Clayton (05-07-2023)
05-07-2023, 07:59 PM
Clearclick to capture. which has worked great for the 50 videos I've converted so far. Then I would (OBS or Photoshop) to correct the color and deinterlacing. Im just doing family movies and on a budget . Someone just told me it was overexposed because when I lower the brightness and contrast it completely washes it out. I've been messing around with this all day.LOL and I'm sure your going to laugh at this but I recaptured, darkened and just for kicks video taped my computer screen with the IPhone 15. Added a “vivid warm” filter. At least the details came through. Obviously there is a more professional way to do this but I am on a budget. Any advise you can give would be greatly appreciated.
File Type: mp4 10000000_9841441219203185_2217599893981880205_n.mp4 (8.61 MB, 4 downloads)
05-07-2023, 09:40 PM
I don't know anything about the Clearclick so can't help you with that.
05-07-2023, 11:15 PM
This is an infamous low-quality device, and will never give you proper results.
No how much you may "like" it (why, exactly?), it's just not very good.
Worst of all, it's expensive. It's essentially an Easycap (less than $2 to produce, sold for $10-20, or even $50-100 rebadged under low-end "brand names" like Roxio), with an added SD slot.
to correct the ... deinterlacing
What do you refer to here?
Interlace is how analog video exists. There's nothing to "fix", and in fact the ClearClick (ClickCrap) messes with interlacing. Yes, for later viewing, you may need to deinterlace (example" Youtube), but nothing needs to be "fixed".
OBS and Photoshop are the wrong tools for video color correctopm. You're essentially using a hammer to twist in a screw. Premiere can, however, though it can usually greatly benefit from a pre-process using Avisynth. You don't want to "color correct" errors, making overall video quality worse.
Don't do that.
In fact, ideally, don't use OBS at all.
For that matter, get a better card. You're wanting quality, and that device simply cannot do it.
Yep, bad.
Yep.
It's the device. No amount of settings will unring that bell.
That $175 that you spend for the crappy card would have been better spent elsewhere. While I do not suggest super-budget whatsoever (as quality will suffer, and you make more work for yourself), you can plod along with the right tools. I would suggest returning it, and letting us guide you to better cheap(skate) options.
No.
This is a misnomer.
- Quality is not "professional".
- And "budget" does not mean crap.
Crap means crap.
Professional just means you charge $$$ for it, and you can still use crap to do it. (Sadly, many service do use crap. Some are even proud of their junk, making Youtube videos that shows their operation is worse that what users can do at home.)
There are quality budget paths, though the more you pnich pennies, the more you sacrifice in time and sanity. Which is exactly what you're facing here.
Video should not be this hard, and is not this hard when you the correct tools. The main obstacle is overcoming cheapness, and the wrong idea about costs.
A video hardware budget should match a good desktop computer budget.
Not a cheeseburger, a month of Netlfix, or whatever.
Not even the cost of a single hard drive ($100), which is obscenely low.
Return that ClearClickCrap, and buy something that doesn't make your video life miserable. For $200(ish), there is a narrow path for better quality (compared to what you're getting now), though some nuisance still involved. It's far from ideal, far from actual "quality". And yet, vastly better than the junk you're punishing yourself with.
I'd also mentioned that "family movies" will someday matter to somebody, even your later self. Don't screw it up. Otherwise you'll just end up the bad guy, the a-hole, at some point in time. I could tell stories about how botched video work led to family infighting, and how we had to redo lazy cheapskate projects with quality that the rest of the family enjoyed. Sometimes the person who botched the project realize they were cheap/lazy/stupid (their words!), often young, and had me redo their unwatchable mess from the original tapes.
The following users thank lordsmurf for this useful post: S_Clayton (05-13-2023)
05-11-2023, 12:55 AM
ammarqureshi93 ammarqureshi93 is offline
The type of product that is used is irrelevant. VHS quality itself isn't the best, but to counter your argument with "low quality devices" I've used a $4 "Easycrap" device that worked perfectly fine. Yes its not perfect and I have decided to use software called --SPAM-- that literally changed all my VHS videos and made them twice as better. The software itself is $40 for one entire month to use. It uses AI and machine learning to reencode the videos and make them better. In all honesty, I would suggest people to use that. It doesn't matter what device you are using, but if you want to use advanced AI to retouch your videos then use --SPAM--. Theres nothing you can say about the AI being bad because its advanced enough that it has been exposed to millions and millions of videos to capture the fine details to apply to the video. Theres also several other editing apps as well, but none of them are powered by AI. The software has received good feedback and is consistently improving. I don't regret at all spending the $4 on my capture card paired with the --SPAM-- software. Please don't misinform people too.
The following users thank ammarqureshi93 for this useful post: S_Clayton (05-13-2023)
05-13-2023, 06:14 PM
traal traal is offline
Originally Posted by ammarqureshi93 View Post
I've used a $4 "Easycrap" device [with] software called --SPAM-- that literally changed all my VHS videos and made them twice as better. The software itself is $40 for one entire month to use. It uses AI and machine learning to reencode the videos and make them better.
Interesting. Those EasyCap devices can't capture losslessly at full VHS resolution, so you're paying $40 a month to do something AI video enhancement software is good at, removing the digital artifacts caused by the EasyCap device and restoring the full resolution.
But you would get even better results and save money in the long run with a proper capture card.
Someday AI will be able to improve VHS to DVD quality, but that day has not yet arrived.
The following users thank traal for this useful post: S_Clayton (05-13-2023)
05-13-2023, 09:24 PM
Thank you for responding. Believe it or not, I have a YouTube Channel where I upload 1980s baseball and softball games. Without going into too much detail, In the 70's and 80" there was a Little League ballpark in my neighborhood. Thousands of low income kids played ball there. Six months ago I formed a private Facebook Group to share our memories and team photos. Within three months I had 500 members (coaches and former players) with no scammers. Then I discovered a lot of old VHS tapes of the games that my dad had recorded. I purchased the "clear crap," as you term it, converted the tapes, created a public youtube channel and and the audience watching the games is overjoyed with the results. They are not trained digital editors, and neither am I.
But something is clearly wrong with this one game. If it was the "clearcrap" the other 50+ hours of games I've converted would have looked the same. Perhaps it's the film because Ive watched the whole game and when the recording stops and a new game starts the colors are fine. I'm not sure, which is why I contacted Digitalfaq to ask if you'd seen anything similar. If you haven't, it's fine to say, "I've never seen that before." During the video I noticed that someone else had a large video camera with a microphone set up about 5 feet away. I wonder this this could have caused interference. But I have no clue just something I notice. If this section of the tape is defective then I would need to hire a service to restore the color? Or maybe its not possible to fix it. I would be willing to pay someone to fix it but I would want to see a small clip repaired first. IF you believe you can repair this one (1 hour game) please let me know.
Im downloading AVC Labs now. Ill keep you posted
05-14-2023, 01:16 AM
The main issue I see with the Clearclick is that it appears you can't control the recording parameters such as brightness and contrast, which this particular recording needs adjustment for during capture.
I have a similar recording with blown-out brightness; I can't recall what I did wrong when I was filming; maybe I bumped some setting on the camera.
A traditional capture workflow that uses a "standard" USB digitiser will give you the ability to control the brightness and contrast, but involves much more mucking around with software (and probable heartache). Quite frankly, I'd be sending the tape out to get that one recording captured with more appropriate gear.
Surely there is a DigitalFAQ member who can help here (or recommend someone)? If I wasn't in Oz, I'd do it for you.
05-14-2023, 01:33 AM
You can't make chicken salad out of chicken shit, That's not how it works. No amount of AI can recover what is missing that didn't get picked up by a lousy capture workflow in the first place.
05-14-2023, 06:56 AM
No.
"Fine" can have no standards whatsoever.
In fact, "fine" is a meaningless filler words in modern use.
Q: "How are you?" --- A: "Fine." ... as you sit in abject pain, upset, etc.
You know what else would have done that? Likely exponentially better? Using a quality card. Not some Chinese USB POS that literally costs about $1 to make. You think you're getting quality for $1 of parts? Those cheap cards come from the same place where you buy fake SSDs drives, and other cheap knockoffs items. Most Easycaps use reverse engineered chips, but cheaply made and worse than NXP/etc they're based on.
It uses AI
AI has become a synonym for "magic" to most people. They have no idea how/why it works, it "just does" (magic!). Well, some of us know the exact processes being used. Seeing actual samples of your video would likely betray them as having merely been hit with aggressive NR and sharpening, maybe contrast pumping, while leaving massive underlying issues.
Interesting.
The person was a spammer.
You were suckered by a spammer. Do not download.
No.
It's rare for me to see an error I've never encountered. Video has been my hobby, then profession, for over 30 years now. I specialize in consumer analog sources.
One issue here, however, is that random services often use random gear. You may find some cheap amateur "service" that uses Easycaps and Elgatos, no TBCs, and gives you a video worse than what you already have. But at the other end, higher end, services have minimum $ and tape requirements.
Those samples in the first post are simply awful. I'm tempted to do it simply to show what is possible. However, the overexposure is not going to be correctable beyond the point of full washout. There data is gone, replaced by white/bright.
05-14-2023, 07:18 AM
You missed the point. I'll bet we could get a better capture the ClearClick because we could adjust the levels. Sure, it probably wouldn't meet the "perfection" standard, but S_Clayton is pretty passionate about this by the looks and I'm sure they'd appreciate any better.
05-14-2023, 07:28 AM
No, did not miss the point.
Unfortunately, I've found that people excuse their own work, but then become unrealistic with what others can do. For example, expecting back perfect values in clear HD/4K resolution. People go from junk to impossible far too quickly. So expectations must be realistic.
- Vastly better is possible.
- But overcoming some overexposure will not be possible.
05-14-2023, 07:43 AM
LS, the guy just needs help. Are you going to suggest a $3,000 system for an hour of video?
They've already said they are prepared to pay on the proviso they are given a small sample to check.
05-14-2023, 10:00 AM
What I see is "I am on a budget". Restoration is not a budget task.
And then "but I would want to see a small clip repaired first". Unknown where that clip would come from. Or does he refer to just a random clip from some other project?
Unfortunately, we're now rejecting most single-tape projects. Not all. Case by case. But most. People started to get rude/impatient in 2021, and that sort of BS is not worth the money. It was always those with 1-2 tapes, never those with dozens or more. They were all nicey-wicey to start, but quickly turned into clients from hell.
This is not one that I'm inclined to do. It would only be more interesting if there were several tapes, in order to create a "ClearClick vs. quality capture card" sort of sample body. But I can't do it for free, and we now have a $100 project minimum (not per tape, but per project).
What he has now is not working.
What he needs is somebody with better gear, if unwilling to buy for DIY.
But honestly, everything I saw was dreadful. It should all be re-done. So I do think better DIY is needed here. You don't need the $3k setup (even if ideal), but you can try to scrape by with less than $500 in gear.
I've been helping in the thread, and can continue to do so in the thread. But as far as "helping" (do the work myself), it's just not an option here.
The following users thank lordsmurf for this useful post: S_Clayton (05-14-2023)
05-14-2023, 10:29 AM
All this back in forth is silly. I understand you are an experienced professional that has been doing this a long time. You see clips and know exactly how to fix them, know when it is crap due to cheap hardware, and know how much better the clips can be. I am a rookie to say the least. Although I love learning the correct way to do things no matter what it is. So, can you detail the names of the equipment you know is best? However, based on your input, there may be no hope for this particular recording. Minimum improvement if any. Honestly, I was referred to this site by several people and knew a experienced person would let me know if it was repairable or not. Thank you sharing your knowledge and I look forward to your response.
05-14-2023, 10:33 AM
What I meant was, it removes aliasing artifacts (also macroblocking, etc.) caused by the awful capture card and thereby makes the video a little more watchable. But I agree with you, it doesn't really restore anything or bring the quality up to the level of a good capture card.
Weird lines on capture Flowerpot Capture, Record, Transfer 2 03-24-2022 04:39 PM
Canopus ADVC-100 giving weird colors? mbassiouny Capture, Record, Transfer 1 06-12-2021 09:55 AM
Bentley's first capture: critiques wanted! Colors washed out? bentley Capture, Record, Transfer 8 06-15-2020 08:50 PM
Hi8 playback and capture colors not right? colony Capture, Record, Transfer 9 03-06-2020 07:19 PM
Weird vertical lines on VHS capture? Specific Capture, Record, Transfer 5 09-03-2018 05:23 AM
