05-09-2023, 06:03 PM
ThumperStrauss ThumperStrauss is offline
My main video restoration project is 8mm camcorder tapes with a few VHS tapes. I also have MiniDV tapes that could use some love. I have experimented with Vapoursyth filters inside the Selur Hybrid software. A few months ago, I started using a dev version of Hybrid, which includes a lot of AI(?) upscalers. I found that most made my videos too cartoony looking. The only one that was good was RealESRGAN in the mode RealESR-general. I recently installed the newest version of Hybrid on another computer and discovered that it includes another AI(?) upscaler called RealCUGAN, which I used in the mode SE and with TTA enabled.
I haven't found very many discussions about RealESRGAN or RealCUGAN, and whether these upscalers make a lot of the rest of the filters unnecessary, such as the denoise filters. For instance, I found that when I used RealESRGAN, using the denoise filters in QTGMC didn't change the final video.
I have attached some images from a MiniDV tape that was upscaled with the default settings in Selur Hybrid Vapoursyth, RealCUGAN, and RealESRGAN. In my opinion, the RealESRGAN looks the best.
File Type: jpg 3.Upscale_with_RealCUGAN_mode_SE_with_TTA.jpg (92.8 KB, 6 downloads)
05-10-2023, 01:08 PM
Selur Selur is offline
You are aware, that RealCUGAN is meant for anime image super resolution, right?
�� Real-CUGAN�� is an AI super resolution model for anime images, trained in a million scale anime dataset, using the same architecture as Waifu2x-CUNet. It supports 2x\3x\4x super resolving. For different enhancement strength, now 2x Real-CUGAN supports 5 model weights, 3x/4x Real-CUGAN supports 3 model weights.
source: https://github.com/bilibili/ailab/bl...N/README_EN.md
RealESRGAN: tests and comparisons ThumperStrauss Restore, Filter, Improve Quality 0 02-16-2023 09:11 PM
JVC versus Panasonic s-vhs - a simple comparison heym56 General Discussion 1 08-16-2016 01:40 PM
JVC versus Panasonic s-vhs - a simple comparison heym56 General Discussion 0 08-16-2016 05:00 AM
When to use DVD+R versus DVD-R ? SSStudio Blank Media 8 12-22-2009 12:26 PM
MMC 8.7 versus MMC 8.9 Triassical Capture, Record, Transfer 2 11-26-2004 03:23 AM
