11-14-2023, 08:57 AM
idan182 idan182 is offline
Hi all
I'm trying to drag 2 files from a folder to Hybrid.
It makes 2 sources on the steam selection.
But when exporting both of the files, the video is the same as the 1st file.
Both of the videos are the same.
Am I doing something wrong?
11-14-2023, 11:47 AM
Problem solved with version 2021.01.31.1 for Win 7
Create chapter files for Hybrid? vhsnewb Encode, Convert for streaming 1 02-12-2023 12:14 PM
Selur Hybrid: Blu-ray files, x264 correct codec to use? ThumperStrauss Encode, Convert for discs 1 03-30-2022 01:46 AM
Hybrid .mp4 files only playing audio? andrewprjnn1 Encode, Convert for discs 2 04-04-2021 05:26 PM
Selur's Hybrid poor resource utilization on large files? JohnCaldwell Encode, Convert for streaming 2 07-24-2019 12:55 PM
How to join multiple AVI files into one file? via Email or PM Edit Video, Audio 1 09-21-2012 02:46 PM
