03-02-2024, 05:54 PM
mike919 mike919 is offline
In the file attached, in a still-frame image, the de-interlacing (which is placebo) has little square pixel artifacts while movement is a little high.
In Capture.PNG are my Hybrid de-interlace settings.
Any help or suggestions on why this is caused?
03-03-2024, 06:49 AM
Selur Selur is offline
without an unprocessed sample of the source, my only advice is: do not use 'placebo'
03-03-2024, 07:31 AM
Yeah, it seems like "Slower" works perfectly for Lagarith Lossless .avi files.
03-03-2024, 01:48 PM
traal traal is offline
It's a 29.970fps source video according to the Hybrid screenshot, but the soldiers don't look American, so maybe the interlacing was "baked in" when the video was converted to NTSC.
03-10-2024, 01:31 AM
The "slower" preset softens, so I always try "faster" first, then "medium". If medium still not enough, I'll try to "switch" ("-this -that") the script before giving up and using slower.
Baked-in from PAL/NTSC conversion is a good guess, I've seen that before.
QTGMC deinterlace = lost detail? bakerie Capture, Record, Transfer 8 03-30-2025 07:57 AM
Deinterlace a DVD lossy using QTGMC hybrid? jedi55 Restore, Filter, Improve Quality 4 04-20-2022 04:51 AM
VapourSynth + QTGMC Deinterlace + Hybrid FAQ for macOS ELinder Restore, Filter, Improve Quality 0 03-16-2020 09:01 AM
Color flicker after QTGMC deinterlace? mrb5217 Restore, Filter, Improve Quality 16 03-20-2017 04:15 PM
Symbols on DC power supplies? Square inside a square? Jurgeaustin Digital Devices 4 07-03-2012 05:59 PM
