10-21-2011, 01:25 AM
LukeS LukeS is offline
Would it be better to feed the s-video out of a high quality none TBC VCR through a DVD recorder that removes tearing like the Panasonic DMR-ES10, then through an external TBC.
OR
Get a VCR with a good internal TBC and run that through an external TBC?
10-25-2011, 04:06 AM
No. The ES10 (and similar) are not transparent to the source, excluding the timebase corrections. The Panasonic DVD recorders posterize the signal (color palette compression), and have some degree of temporal NR. That noise reduction can cause ghosting of motion, and oddities in the image.
Ideally you only want to use this setup when it removes worse errors than it adds.
Yes, this is best. As per reason above.
Some of this has been discussed in far more detail on the forum in past months and years.
Look up "es10 passthrough" and then browse the various results.
Wanted Panasonic DMR-ES10 DVD recorder, to use for bypass rodbuilder Marketplace 10 08-30-2011 02:59 PM
Service Manual for Panasonic DMR-ES10 DVD Recorder [DOWNLOAD] Tuco Video Hardware Repair 3 07-19-2011 12:12 PM
Panasonic ES10 units for sale! (frame sync filtering!) lordsmurf Restore, Filter, Improve Quality 0 08-28-2009 03:30 AM
Question on the Panasonic DMR-ES10 mrwhitethc Restore, Filter, Improve Quality 4 04-13-2008 07:30 AM
Philips 3575 vs Panasonic DMR-ES10 vs Toshiba XS?? Konfusion Capture, Record, Transfer 4 02-03-2008 08:54 AM
