Go Back    Forum > Digital Video > Video Project Help > Encode, Convert for streaming
05-06-2016, 06:25 AM
mike1983 mike1983 is offline
Hi guys, i need to demonstrate my screen on a TV (3ds max) i will explain working process to my auditory, so i have HDMI output from my videocard , this encoder modulator and existing coax network, i plug HDMI feed to modulator and i have coax out which is connected to TV, everything works fine, except 3d models inside 3dsmax window. What do i miss? Can you advise me any alternatives for this application, but i need coax out for sure because i have existing coax network and PC i far away from TV, i can't just use HDMI out. Thank you.
07-12-2016, 04:56 PM
Fiber_Guys Fiber_Guys is offline
Hi Mike,
That's something the manufacturer should be able to help with; I purchased this encoder modulator and it works beautifully with 3d. We are also using the low latency options and IP/RF output without any issues whatsoever. Its a plug and play unit that the manufacturer helped assist in installation and optimizing into my RF architecture without a hitch. Call em up and see if they can help!
Tips on fixing JVC HR-S8000U dim VFD display? Matt Fisher Capture, Record, Transfer 10 01-11-2026 08:57 PM
Dupe content a.k.a. Google doesn't care if you own the content admin Web Development, Design 1 07-25-2013 07:04 PM
Spyder 3 vs Eye-One Display 2 for monitor calibration manthing Photo Processing, Scanning & Printing 1 02-07-2012 05:02 AM
Unable to get Flash vid to display in transparemt mode vidweb Encode, Convert for streaming 5 03-04-2011 04:56 PM
Interlacing display Question admin Videography: Cameras, TVs and Players 0 01-22-2009 07:47 PM
