02-27-2022, 05:41 PM
newby newby is offline
I have an ATI 600 USB but wanted to try out an osprey 260e as it has some interesting features.
Using DVK-200 to generate color bars and the 260e config utilities (all connections are S-vid).
DVK>260e
DVK>DMR-ES10>260e - black level controls dark/light (input/output)
DVK>ES10>260e - dark/light w/ NR enabled (looks better to me so I left it on for the rest)
DVK>ES10>260e - light/dark
DVK>ES10>260e - dark/dark
DVK>ES10>260e - light/light
I settled on ES10 on dark/light NR enabled. Now a control:
DVK>JVC-HRS9911U>260e
DVK>ES10>JVC>260e
Finally adding in Elite Video BVP
DVK>ES10>BVP>JVC>260e - BVP in 'wipe' aka passthru
DVK>ES10>BVP>JVC>260e - BVP adjusted as best I could to 'restore' output to match original
The following users thank newby for this useful post: wimvs (03-03-2022)
02-27-2022, 05:49 PM
With that fun done I added the DVK back into the chain:
JVC>ES10>DVK>BVP>260e
In this chain, I can utilize the DVK freeze frame functionality to make adjustments. JVC R3 disabled, TBC on, analyze on/auto
JVC>ES10>DVK>260e
JVC>ES10>DVK>260e top histogram, JVC>ES10>DVK>BVP>260e bottom ( I missed clipping the the actual capture w/BVP)
JVC>ES10>DVK>260e
02-27-2022, 05:59 PM
I had a monitor (dell 2408WFP) arrive damaged so I've not calibrated the display but subjectively the BVP just kinda makes everything look better (I played with Shrek2 going through ES10>DVK>BPV>ATI 600 and felt the same).
However, the BVP clearly needs some adjustment (wipe is not fully leaving the left side) and the histogram looks funky on the white bar. Furthermore, the roll off is softer on the ends and black/whites may be blowing out according to the histogram. Ultimately the box may not be bringing anything to the table that modern vdub/avisynth processing cant do.
The other fun thing I did with DVK>260e was individually test all of my cables. All looked very similar though I did see little more noise on one type vs the other. Aside from monitor calibration I also still need to make up some chassis ground cables for all of the components before I start capturing for real.
02-27-2022, 06:53 PM
My BVP also has the left vertical split too far within the frame to easily mask.
Though it’s a side note of your post, I have my BVP4+ at a shop for scrutiny and hopefully adjusted.
03-01-2022, 07:44 AM
AFAIK, there is only one adjustment internally and it affects right side scan/sync.
Where are you having your unit serviced? I'm thinking the screen split pot will need replaced to remedy the issue. On my unit it's a Mouser 500k
Originally Posted by newby View Post
DVK>ES10>JVC>260e
Just FYI I can't edit the original post for some reason but FYI the copy/paste job on these descriptions is out of order as well... ES10 was AFTER JVC so:
DVK>JVC>ES10>260e
DVK>JVC>ES10>BVP>260e - BVP in 'wipe' aka passthru
DVK>JVC>ES10>BVP>260e - BVP adjusted as best I could to 'restore' output to match original
Best capture workflow for Mac Moonbeam Capture, Record, Transfer 0 03-27-2022 12:16 AM
How are the Osprey 210e cards? waloshin Capture, Record, Transfer 2 12-13-2021 03:14 AM
Best workflow for VHS capture? RobustReviews Capture, Record, Transfer 34 11-15-2020 04:20 AM
Capture Interlaced (60i) VHS and convert to 60p? Osprey 260e + Virtualdub? analog2digital Restore, Filter, Improve Quality 2 03-11-2020 11:13 AM
Unable to change output to 720x480 - Osprey card issue? kriscraigs Capture, Record, Transfer 2 01-28-2019 04:26 PM
