02-20-2024, 02:11 PM
BruceOlsen BruceOlsen is offline
We have a friend who performed and recorded a concert in Sri Lanka. It's up on YouTube here:
https://www.youtube.com/watch?v=AfzpuDp98F4
Some of her friends/family around the world need to see it on DVDs, but it sounds like the videographer is dragging his feet.
So I was thinking of downloading it and burning a couple of copies for her, but I'm in the US, and I have no idea where her friends are. I haven't burned DVDs (with menus, etc) previously, but I get the concepts and I'm willing to give it a shot with the copy of Corel Video Studio I have.
Q1: on the source side I assume I'd like to download the best quality version, which YT calls "1080p50 HD". It also lists 720p50, 480, and on down. would I actually be getting 50fps and would I be able to burn that as-is? Or would I have to do some kind of processing on it?
Q2: Assuming I can burn region-free DVDs, would I need to burn different DVDs for different regions anyway (does each region potentially use its own frame rate due to PAL vs NTSC, etc)?
I really don't want to get stuck in some kind of quagmire.
Thanks so much in advance.
02-22-2024, 07:05 PM
Wish granted. PM'd.
Maybe, not necessarily.
It's not p50, it's p25. (I downloaded it.)
Not if it were 50. But it's not, it's p25.
However, not as-is, it is not ready for DVD yet. (But now it is. )
Yes. (But no. )
All burned DVDs are region-free. But regions have nothing to do with PAL or NTSC.
Yes and no. Again, do not mix up regions with formats.
- All PAL can play NTSC.
- Most NTSC can play PAL, unless the players in ancient POS DVD player. Or strict Blu-ray player (like my Samsung from 15 years ago).
But the source is PAL, not NTSC. Converting to NTSC is possible, but not easy. (Well, actually, it is easy if you want to screw up quality. But proper conversion is 25>23.97, played back with pulldown, with a 4% audio shrink. More work than I'm able to do right now.)
Corel is the wrong tool.
What you wanted was really easy to do, at least for me it is/was.
- yt-dlp
- OPTIONAL: Avisynth convert rec.709 to 601 ... which I didn't do here, not worth it
- VirtualDub2 to resize 720x480
- MainConceto to encode MPEG
- TMPGEnc Authoring Works for menu-less folder author
- Imgburn to create DVD-Video ISO
- and then use VLC to play ISO
No menus, 3-minute interval chapters.
DV to Blu-ray: Burn as data, or encode as Blu-ray? HomeVideoProject Encode, Convert for discs 4 11-21-2023 08:32 PM
YouTube channel with 1970s video tape captures keaton General Discussion 2 06-01-2018 05:47 AM
How to clean Youtube video quality? wfogler General Discussion 6 01-11-2017 02:44 AM
Capture Amazon Video and burn on DVD? w3tno Encode, Convert for discs 21 11-13-2013 08:28 PM
