07-31-2024, 02:52 PM
mike919 mike919 is offline
So basically, I am wondering If I have A/V cables plugged into my TBC, and my TBC outputting S-VIDEO... Is there any loss of quality during that process?
If you don't get what I am saying, something like this...
VCR--A/V-->TBC---S-VIDEO---->Capture card
mike
07-31-2024, 03:02 PM
That would be fake s-video (recreated by the tbc), not sure how good that would look (probably so-so)
07-31-2024, 03:22 PM
Here is a sample screenshot, It has harsh DNR from the DMR-ES15 because I haven't turned it off yet.
07-31-2024, 03:25 PM
It would still look better than composite in - composite out, Having the DVD outputs S-Video gets rid of the second stage loss if the signal is converted back to composite.
07-31-2024, 03:44 PM
No no, its composite in - s-video out, straight to the capture card
mike
07-31-2024, 11:07 PM
aramkolt aramkolt is offline
Typically, I think you'd always want to use the highest bandwidth output from your TBC which should go in this order of priority depending on your model assuming your capture card supports it. Note, the "recommended" TBC's won't have anything above S-Video:
1. SDI/HDMI (which is a type of digital component output)
2. Component Video
3. S-Video
4. Composite
In your case, I'd use S-Video from the ES15.
07-31-2024, 11:11 PM
My TBC is being outputted with S-VIDEO, My VCR is inputting composite. I was wondering if the VCR input composite loses quality when being outputted through the TBC S-video. Confusing? Yes, this is the best way I can probably explain it
mike
08-01-2024, 02:04 AM
Yes I know what you are talking about, read my above post again slowly to digest it.
08-01-2024, 04:19 PM
Yes, but the signal isn't being converted back to composite. Its being outputted through S-VIDEO.
mike
#svideo #workflow
Composite vs. s-video output mod, image quality comparision ofesad Capture, Record, Transfer 22 10-04-2024 02:49 PM
Is VCR actually effecting output video quality? connorinspace Restore, Filter, Improve Quality 6 10-03-2020 03:10 PM
Best VCR with s-video output, or advice to adjust playback quality? crissrudd4554 Capture, Record, Transfer 13 05-17-2018 02:07 PM
S-video to RCA quality loss rodbuilder Capture, Record, Transfer 1 07-15-2011 12:33 PM
TBC, but with minimum possible loss of quality deserthighway Restore, Filter, Improve Quality 1 03-25-2010 08:56 PM
