Quantcast New DVD burner issues - digitalFAQ.com Support Forum
Go Back   digitalFAQ.com Support Forum > Digital Video > DVD Project Help > Copy DVDs, Duplicate, Replicate
06-21-2008, 02:37 AM
naga naga is offline
Got a new computer and was able to install DVD Fab and DVD Shrink. DVD Shrink is unable to burn DVDs till I Have Nero installed. Having trouble making my version of Nero recognize my DVD burner, it is "PLDS DVD+-RW DH-16A6S SCSI CdRom Device". Tried getting the latest version of Nero but didn't like the all the price tags along with it. At the moment I'm able to get the file to ISO format or videoTS folders created.
Anyone know how to make DVD Shrink burn without Nero or know how to get a free new version of Nero?
__________________
From Womb to Tomb I'm a Gamer!
06-21-2008, 04:25 AM
ryan_logan ryan_logan is offline
you can just use dvd decrypter to burn the isos, its free. You can also select it to burn automatically after shrink is done, just select bun with dvd decrypter in shrinks target device.
06-22-2008, 07:13 AM
Use ImgBurn. http://www.imgburn.com/index.php?act=download
and then use the new DVD Shrink version that uses ImgBurn to burn:
http://forums.afterdawn.com/thread_view.cfm/521885
Forget about Nero, it's turned in a piece of crap. I remember the days when you and I burned discs and Nero was the only good program. My my, how things have changed.
ImgBurn is the burning-only redo of DVD Decrypter.
To read discs, DVD Decrypter often works still, but DVD Fab Decrypter is often needed on discs from the past 2-3 years.
FYI, your burner is a LiteOn drive, quite decent.
NOTE: Burning DVD+R DL discs is nowhere near as easy as single-layer DVD-R and DVD+R media. Just so you know. I still suggest Verbatim DVD-R or DVD+R, but know I prefer Verbatim DVD+R (I get less coasters). Sony "made in Taiwan" is another fine choice.
__________________
Read these 3 DigitalFAQ Notes:
1. You must be logged in to see images or download attachments. Not a member? Register now!
2. Like this site? Did my writings help you? Then upgrade to a Premium Membership or give a small Donation. Also Like on Facebook or Follow on Twitter.
3. Discuss television shows, cartoons and DVD releases at the TVPreservation.com Forums.
06-26-2008, 12:08 PM
Thank you. Able to burn DVDs on my new machine. It's really awesome having a quad core. Able to play a game while encoding and burning a DVD without any drop in performance.
__________________
06-26-2008, 02:33 PM
MagnificentMarcus MagnificentMarcus is offline
I disagree about Nero, but Imgburn is the way to go. Personally, I use use DVD2One or CloneDVD2, but you have to use AnyDVD too!
8mm playback problems, tracking and audio issues admin Capture, Record, Transfer 0 10-08-2009 09:03 PM
Virtual Dub Filter Issues & Questions Konfusion Restore, Filter, Improve Quality 11 02-20-2008 08:54 AM
Color Corrector issues? wheezer210 Capture, Record, Transfer 1 05-31-2006 09:10 AM
DVD-VR Issues Neuroslicer Encode, Convert 2 09-21-2005 10:17 PM
ATI AVI Synch Issues blazey Capture, Record, Transfer 18 10-18-2004 06:36 AM
All times are GMT -5. The time now is 01:26 PM  —  vBulletin Copyright © 2011 Jelsoft Enterprises Ltd  —  SEO by vBSEO
