04-27-2014, 11:08 PM
Needs to work with P4 2.4 Ghz 2GB ram running XP. Thank you.
04-28-2014, 05:26 AM
the card you want is the all in wonder 7500 VE
this is a PCI version of the 7500
there are a few listed on ebay
04-28-2014, 09:47 PM
Thanks Volksjager,
Do you happen to have either the AIW or sound blaster?
04-28-2014, 09:51 PM
i have an SB card posted on ebay together with a 7500 AGP card, but it isnt the 2 ZS you asked about.
there should be some of those on ebay as well.
the only AIW cards i have right now are AGP
The following users thank volksjager for this useful post:
vhsdigital34 (04-28-2014)
04-28-2014, 10:25 PM
Thanks Volksjager, I appreciate the info
04-29-2014, 10:12 PM
We have a handful of old AGPs matched up with SB cards, too. Those still give the best VHS conversions and analog recordings.
04-29-2014, 10:21 PM
Thanks BuffaloChuck but my rig only has PCI slots
04-30-2014, 05:24 AM
For us, it's the software that gives us the power and flexibility for 'best' results, not the AGP or PCI connector - but the 'old' software, so if you can find those 7500 or 8500AIWs, their software should be equivalent to the last of the AGPs'.
04-30-2014, 07:33 AM
it is definitely worth swapping your motherboard to one with an AGP slot
lordsmurf (05-01-2014)
05-01-2014, 06:12 AM
The Theatre Rage (100) and Theatre 200 chips are what matter, not AGP vs PCI vs PCI-E.
Creative Sound Blaster cards actually not as good as Turtle Beach cards, but those are much harder to locate these days.
vhsdigital34 (05-20-2014)
05-20-2014, 08:11 AM
Hi lordsmurf,
Would the turtle beach card work on my set up (P4 2.4 Ghz 2GB ram running XP)? If so, would any turtle beach card work? I see a few of them on eBay but not sure if they're the right ones. Thank you
05-20-2014, 09:59 AM
Thank you Lordsmurf!
Just got one for $15! Just need that AIW now. =)
05-20-2014, 10:00 AM
None of these cards would capture stereo though, correct? I only see a line in jack on these
05-20-2014, 09:00 PM
yes they are stereo - you can use either:
1: a "Y" cable - red/white RCAs on one side and 3.5mm stereo phono jack (line in) on the other directly from your deck
2: an internal cd/aux audio cable from the ATI card to the sound card using the internal connectors on the cards
3: the ATI breakout cable to the line in jack
vhsdigital34 (05-21-2014)
05-21-2014, 08:26 AM
Thank you very much Volksjager!
05-21-2014, 11:28 AM
I assume the turtle beach cards are used for analog only capture, such as converting cassette and records to digital audio? Would these help with video capture when using an All-In-Wonder (AGP) capture setup?
05-21-2014, 12:44 PM
The topic of the thread was ATI AIW cards ... so yes.
Lightsword (05-21-2014)
05-21-2014, 01:42 PM
Thanks, just wanted to be sure
06-06-2014, 10:08 PM
Hi,
Just got my hands on the 7500 ve radeon PCI card. I assumed this would work with the regular 4 pin mini din. Looks like the input is actually a non standard 8 pin mini din. Is there a place that sells a 4 pin SVideo to this 8 pin mini din or is there an adapter somewhere I can get? I can't test whether the card works cause of this roadblock. Any help would be appreciated. Thank you very much
