Go Back    Forum > Digital Video > Video Project Help > Copy DVDs, Duplicate, Replicate
07-06-2023, 09:01 AM
MemoriesSea MemoriesSea is offline
Hi guys
Some years ago I converted my VHS tapes to CD which I would now like to be on an external SSD. How should I approach this project and how can I retrieve and make sure that I get the highest quality available from these CD? Storage is not an issue as I would just like to get the highest available quality. Note - I still have the original VHS tapes laying around.
Thanks in advance!
07-06-2023, 09:34 AM
It depends on what format the "CD" is. Are you sure it's a CD and not a DVD?
To start, put one of your disks into your computer and using Windows Explorer, single-click on the left column icon for the drive (so that Autorun isn't triggered). The content of the disk should then be visible in the right pane.
Take a screenshot of the expanded disk contents and post it here. Then we can advise.
In any case, it should be a lossless process so your quality will be retained.
07-06-2023, 09:46 AM
Thanks for the quick reply. Upon further looking I think the media drive is DVD instead of a normal CD.
I have uploaded a Snapshot.
07-06-2023, 10:39 PM
Are you on a Mac? If so, I can't help.
07-07-2023, 08:32 AM
Yes I am on a Mac, but I can easily access a windows if needed!
Thanks in advance
07-07-2023, 09:29 AM
Good! Mac affect me badly. I saw the three little coloured blobs and thought Arrgggh!
In the absence of any help from an Apple person, put your disk in a Windows machine, open up File Explorer and click on the CD/DVD drive like this:
If you see a Video_TS folder on the right, you have a DVD. Let us know what you see (or take a pic and post it here using the "Manage Attachments" feature).
07-07-2023, 09:37 AM
Hi again.
This screenshot is taken on a MacBook, but the content is like you have said. The disk contains to folders named.: "AUDIO_TS" and "VIDEO_TS".
The AUDIO TS folder is empty and the contents of my VIDEO TS folder is shown in the screenshot.
07-07-2023, 10:06 AM
Do not copy the VIDEO_TS and AUDIO_TS folders. That rarely works well. You need to "rip" the discs, either as ISO, or IFO mode to just extract the video/audio streams (dump the menus, if any, create a single proper MPEG files). Do not use a lossy re-conversion tool like Handbrake.
For Windows, it's as simple as using DVD Decrypter.
For Mac, it somewhat depends on OS, and whether Intel or M based.
The Windows option is far, far easier.
The following users thank lordsmurf for this useful post: MemoriesSea (07-07-2023)
07-07-2023, 10:23 AM
Yes I am aware of this. I have currently saved some of my DVD's as an ISO file, however upon further inspection it seems like some of the VOB file sound are distorted with a lot of noises and hisses. Is this in any way fixable or should I use my VHS tapes to redo the whole process?
My priority is to have loseless quality without anything being lost in the proces.
How to copy Blu-Ray discs? Rookie20 Copy DVDs, Duplicate, Replicate 18 04-01-2021 06:40 PM
Storing DVD discs, how to archive many discs? naripeddi Blank Media 6 07-27-2018 04:40 AM
Don't use gold discs? Bill Downing Blank Media 1 01-09-2011 11:26 PM
MediaRange discs Asterix Blank Media 15 01-19-2010 12:31 PM
Unfinalized discs staypuftman2004 Capture, Record, Transfer 4 03-13-2007 11:43 AM
