Go Back    Forum > Digital Video > Video Project Help > Copy DVDs, Duplicate, Replicate
12-07-2015, 07:03 PM
abrogard abrogard is offline
I have many folders of movies I backup with DVDDecrypter over the last many years and now I want to burn some of them. To look at and for extra safe backup (lost a couple of hard drives recently).
It went alright until I got to one that is bigger than a dvd5 - it is 7.7G.
I thought imgburn was going to do it because it asked me about a break point. But it wouldn't do more than either truncate or overburn.
I thought I'd pick the files up with dvdshrink and massage them but dvdshrink won't pick them up - invalid parameter it says.
What is the best way to deal with such a library of DVDDecrypt rips? Burn most with what? Burn the oversize with what? How?
12-07-2015, 08:06 PM
Do what the creator of the original DVD did, with the same high quality bitrate instead of crapping a high-bitrate video; use a dual layer DVD disc. Most premium quality retail VD movies are dual layer. Verbatim DVD+R-DL is the top choice.
12-07-2015, 10:05 PM
Well that sounds fair enough. I didn't think of it. Was kinda thinking my old dvd burners wouldn't burn a dvd9. They should?
Well okay. I'll invest in some media.
Meanwhile I used CDBurnerXP which did a trouble free job and split the movie across two disks.
I couldn't get anything to else to load the files so I finished up turning to CDBurnerXP, which I found and downloaded today, free thing, no virus or stuff, and put the VOBs I wanted into it.
5 of them. Making about 5G.
It split them up no problem - only funny thing it put VOB 1 on Disk 1 and VOBs 2-5 on Disk2 ! I would have expected it the other way around. Maybe one can reorder them in the list or even rename them, I don't know. Happy to get something done.
Burn DVD by MainConcept catloki General Discussion 6 08-09-2015 10:05 PM
Need to edit teaching video, decrypt DVD - Is this good software? NEOooo2 Edit Video, Audio 4 04-03-2015 08:54 AM
How can I be sure I am getting a quality DVD burn? stylonurus Blank Media 0 10-01-2013 12:09 AM
How to get the best quality from downloaded VHS rips ? via Email or PM Restore, Filter, Improve Quality 1 04-01-2012 12:09 PM
