02-21-2014, 07:13 AM
could someone please answer my thread please? you guys are too busy?
02-21-2014, 07:14 AM
You didn't ask a question.
1- Yes, buy new DVDs for the broken ones. Why are we still discussing this?
2- Yes, the rack is fine.
gamemaniaco (03-03-2014)
02-21-2014, 07:23 AM
1 heat generated by the CRT TV 29'', the heat generated by the dvd player and the heat generated by the channel receiver will not heat up the atmosphere and warm the discs and will not affect the lifetime of the CD / DVD even though they were next to these equipment? look the picture and-demonstration
2 you said the cmc magnetics uses azo dye in DVD + R since 2004 and is a partnership with Mitsubishi, as you get this information? the attendant cmc not tell me it just said that the dye on dvd + r 16x philips was cyanine but did not believe him, I believe in you
02-21-2014, 06:11 PM
02-21-2014, 06:17 PM
1- It's fine.
2- Official docs a decade ago.
02-21-2014, 06:23 PM
do not get me wrong, I want to learn with you
1 I'm not talking about 10 years ago but 2010 till today continues today cmc using azo? My discs dvd + r 16x philips were made in 2010
2 from what I learned with you the azo belongs to mitsubishi and verbatim but the cmc has this patent?
3 I thought the burning rate of the disc had everything to do with the dye type used: cyanine 16x and azo 8x this on dvd
02-21-2014, 07:14 PM
We're not either.
CMC in 2004: "Help me Obi-wan, you're my only hope?" (Star Wars)
Mitsubishi in 2004: "Here I come to save the day!" (Mighty Mouse)
It was a fundamental change in everything they did. And as far as everything/everybody I've seen online, it's not changed. It was a complete manufacturing refit that allowed CMC to house MCC production to this day.
For a CMC "tech" to say that it's one dye burned at one speed, and another dye at another speed, is 100% retarded.
Cyanine is not, and never really was, a good dye. It was mostly unstable on DVD-R. It was discard on CD-R 15-20 years ago for "better" dyes (phthalocyanine mostly). How its "better" can be argued, as pure cyanine had the highest readability, though not the best longevity.
A dye CANNOT magically change. Burned or unburned, the dye is always the same.
02-22-2014, 06:31 PM
We're not either.
Thank Lordsmurf , and you have much knowledge about kpmedia medias
1 if the dvd + r 16x philips manufactured by CMC in 2010 in then you would say that the CMC uses azo dye on all your disks ( philips , memorex ) from 2004 until today?
2 the rise of the cmc for philips dvd + r 16x is a pure and legitimate rise of mitsubishi ?
3 is true that Cyanine ceased to be used in any and all CDR DVDR 15 years ago ?
4 the tech told me that the cmc and cmc manufactures philips dvdr with durability for 30 years , is this true or false ?
02-25-2014, 05:50 AM
Lordsmurf please answer my questions previously posted
02-27-2014, 05:54 AM
can someone answer my questions above, please?
02-27-2014, 06:02 AM
Stop begging. We get busy around here -- doing the video work, the web hosting and development work, and answering questions from clients and Premium Members (of which are you are not).
Also stop asking the same questions over and over.
1. It was a fundamental change in how media was made at those manufacturers. It was a better method, thanks to Mitsubishi's help. Yes, sure, they could have changed, but I doubt it. What was true in 2004 appears to still be true in 2014. DVD has been mature since at least 2008, and nothing has change anywhere.
2. This makes no sense.
3. I don't know about 15 years ago, but I've not seen cyanine in probably a decade now.
4. Once burned, and you verify the burn is good, it should be good for at least 30 years. But the problem is getting that good initial burn.
02-27-2014, 06:23 AM
Thaks for help
Sorry I do not wanna let you guys upset , it seems you're always too busy to be premium customer has to pay ?
1 AZO used by CMC DVD + R 16x Philips 2004 until 2014 is a pure and legitimate AZO dye or is it another ? I need to know the name of the dye used in 16 philips dvd + r manufacture cmc, if this Philips DVD + R 16x Cyanine dye wore this disc was convicted to lose the files in a few months or a few years ? I just received an email from the CMC and he said the dye Philips 16x DVD + R is a Cyanine and like and similar to the Cyanine formula used by Sony and Taiyo Yuden
2 I got discs dvd verbatim copies, to make those my DVD + R with a layer of broken plastic and torn in the center of the disc? I have important files burned these discs , what should I do with essses discs ? Should I throw them in the trash or they still are properly to be stored long term and I keep them stored , can someone analyze this problem and tell me if these discs will oxidize or will get moisture and oxygen inside the dvd destroying data layers and reflective ?
photo is example, red is break one layer plastic
03-03-2014, 09:03 AM
Lordsmurf please answer my questions above
03-03-2014, 10:52 AM
Taiyo Yuden does NOT use cyanine. Their DVDs use Azo! Only the CD-R uses "super cyanine" (stabilized cyanine).
There is no Sony media. Sony is a brand name. Once upon a time, Sony outsourced its own media ID to Taiyo Yuden and Dexon. But those days are long gone. Daxon has been out of business since 2008-2009. And Taiyo Yuden hasn't been used since the 8x era -- long before the JVC buyout.
That CMC guy is a moron.
Somebody is confusing CD-R with DVD-R. I almost wonder if somebody has bungled the information found on our own site!
Ritek may have used a cyanine-based dye at one point, back in the RITEKG01-04 era. For example, asymmetrical trimethine cyanine. Here's an old patent document on that dye: http://www.freepatentsonline.com/6306478.html. But I could never find solid proof of this.
The CD-R days were fairly open compared to DVD-R and DVD+R. Information on them was very guarded, so it's not a simple question to answer.
DVD-R uses organic dyes. And while cyanine is an organic dye, there are others. Cyanine has a number of properties that make it a poor choice for optical media. The above patent document even listed some of them.
You're asking questions outside the scope of what this forum is about. We can help you learn which discs are best, why, and where to get them. But you're asking about the chemistry of discs here. That takes more time to answer than any of us are willing to invest. If you want to learn more about the dyes in discs, I suggest you learn some fluent English, learn Japanese, learn chemistry, and start sifting through patent documents from around 1996-2004.
As far as bad discs go, at least re-burn the contents to better media. As far as what you do with old discs, I honestly don't care. We keep many for research, so you can surely do that. But we often toss bad discs in the trash where they belong. What you do is up to you.
/thread
Thanks.
03-03-2014, 01:48 PM
thanks for help
1 I was already thinking that my Philips DVD + R 16x manufactured by CMC in 2010 used the Cyanine and so I thought I would lose all burned files on these disks before long all this because I thought that belonged only to AZO Verbatim and MAM-A, I did not know that CMC Magnetics had the patent for use in AZO DVDs from Philips
2 it is true that Cyanine is only for CD-R? I have some CD-R's SmartBuy purchased in Brazil, they are good and decent?
3 as the manufacturing process of a DVD + R and works as the first layers of plastic is broken during manufacture of the disc? this means that the rest of the disc is not the glue that keeps out oxygen and moisture inside the dvd?
03-03-2014, 04:55 PM
please someone answer my questions
03-03-2014, 06:29 PM
please repply kpmedia
03-04-2014, 01:39 PM
please repply my questions for medias
03-11-2014, 11:18 AM
can someone answer my questions please?
03-20-2014, 09:52 AM
