12-05-2015, 11:17 AM
What is the best free software to test my DVD drive, optical media and DVD disc burning? I wonder if all of them are 100% good
12-06-2015, 05:05 AM
Remembered
You mean check ..... burning quality ?
not all burners can be used.
Best of all were the old BenQ-1640 + 1655
12-06-2015, 05:56 AM
I have the latest version of Nero CD / DVD Speed but I'm not sure if he check drive
12-06-2015, 06:17 AM
Remembered
Come to the burner depends.
Most burner are not suitable.
What version of Nero?
12-06-2015, 06:20 AM
i use imgburn for burn disc
and Nero DiscSpeed
12-06-2015, 06:29 AM
Use Nero Infotool 4.
But you need a specific burner to run some of the more advanced quality tests (PIF/PEI/PO/jitter).
12-06-2015, 06:32 AM
I want to test if there is any error and problem in my dvd drive, virgin optical disc and burn DVD disc, best free software
12-06-2015, 06:53 AM
Remembered
This is also equipped with the latest Nero Info Tool
[Nero but I have not installed to burn]
Only some burners are suitable for reading in terms of quality.
You have to try
Here is an example ........ DVD from 2008 TY course.
Total I have 15 burners [to try CD / DVD / HD-DVD and BR]
Unfortunately, a DVD burning clean is an art.
12-06-2015, 06:56 AM
I should download the Nero InfoTool? it is full and free?
12-06-2015, 07:00 AM
It's freeware. It use it all the time.
Nero DiscSpeed works fine, too.
I forget which is being used on my main BenQ scanner, as I'm not there right now.
12-06-2015, 07:04 AM
1 Which is better, Nero DiscSpeed or Nero InfoTool?
2 Nero 11 InfoTool is good?
12-06-2015, 07:09 AM
You just need to try them and see for yourself. At some point, posting questions if not as useful as trying it out.
12-06-2015, 07:12 AM
I want a software to save on the PC, not a lot of software, but I want the best
