04-15-2023, 01:55 PM
Paul R Paul R is offline
I use the Sony EV S9000E vcr for capturing Hi 8 and 8mm tapes, however I want to ensure that the on screen display is completely turned off as I don't want generated writing coming out on the capture. There is a "Display" button that turns off certain things but the problem is I still find certain writing flashing up on the screen. E.g. 'SP' or 'LP' still show if there is a change of speed and also 'STEREO' sometimes comes up. This is no use to me atall as I can't have this in the capture, why does this still happen when I have on screen display turned off and therefore how do I stop this from happening?
04-16-2023, 09:13 AM
cbehr91 cbehr91 is offline
I believe the EV-S9000E is the PAL version of the EV-S7000. To disable the annoying on screen "STEREO" you have to place the VTR in edit mode (press the "EDIT" button on the powered pull-out drawer).
IIRC you have to do this every time you power on the machine.
04-16-2023, 10:58 AM
That's great, thank you. Tried that and it has worked.
09-15-2024, 05:45 AM
SFtheGreat SFtheGreat is offline
Which specific button? The "edit standby" button returns the error message that I should playback VCR with lanc cable and set the playback lanc mode to s".
PAL user, unless otherwise specified I talk about PAL equipment.
09-25-2024, 12:54 PM
charlotte.king
Guest
Posts: n/a
Unfortunately, the 'SP' and 'LP' indicators are often hard-coded and may not be entirely disabled due to the way the VCR is designed.
Mitsubishi HS-HD2000U on screen display? Closecall Capture, Record, Transfer 8 04-02-2022 11:45 PM
Betamax LCD screen doesn't display after storage? Jethro777 Video Hardware Repair 0 07-07-2019 12:53 AM
Cyan/magenta capture color cast on Sony EV-S9000E? m4v3r1ck Capture, Record, Transfer 8 01-02-2018 06:50 AM
FS: Sony EV-S9000E Video8/Hi8 deck, good playback [SOLD] juhok Marketplace 2 07-31-2017 12:18 PM
Does anyone have Sony EV-S9000E ? juhok Capture, Record, Transfer 10 12-28-2010 11:20 AM
