01-22-2020, 09:34 AM
FrostBite FrostBite is offline
LS,
What is your current work flow for going to DVD? Capture in VIrtualdub > Upload captured video to virtualdub and edit > save as avi > convert to mpeg-2 (with TMPGEnc Plus 2.524 maybe?) > use those assets in DVDWS2 to create and iso to burn a dvd?
01-22-2020, 10:47 AM
It's 2020, and DVD is now a legacy format, so the processes for it are also legacy.
There's really nothing "new" in terms of software to capture, encode, author, burn.
Or for hardware, meaning DVD recorder.
Method depends on source.
For example, my hobby, master VHS/S-VHS tapes of Cartoon Network, USA, Toon Disney, and others, all exceptional quality. But, of course, even quality VHS has flaws, mostly in timing and chroma. TBCs fix timing, but chroma often overrides NR/TBCs. When encoded to lossy formats (MPEG for DVD, or H264/DivX/H265 etc for streaming), to noise looks even worse as artifacts. So for this, I just use JVC LSI based DVD recorders. JVC S-VHS VCR > Cypress TBC > JVC LSU recorder. And done (for capture). Decompile recording with DVD Decrypter on computer, edit with Womble (MPEG lossless editing) to remove commercials or unwanted footage, re-author, done.
For pretty much everything else, standard capture in VirtualDub with AIW/etc cards, editing/restore as needed (both audio and video, mostly SoundForge and Avisynth+VirtualDub), encode to MPEG with MainConcept Reference/TotalCode, author, burn.
The alternative to MainConcept payware is Avidemux version 2.5 (not 2.6/7/etc).
Authorware has always been mostly 2 styles. You have complicated engineer/CAD type interface, PITA to use, like DVDLab or Adobe Encore, up to expensive things like Scenarist. Or you have dummy-friendly things like TMPGEnc with truly fugly mostly-uncustomizable menus. Ulead DVDWS2 was one of the few apps to truly blend a user-friendly GUI with advanced features and menu creation abilities. It works fine in an XP VM, or in WinVista/7 (probably 8/10) without audio preview.
Imgburn still go-to for burning, but beware of later version that have PUP/spyware attached.
This has been my method for at least 10 years now, and probably will not change in the next 10. Nothing newer is better, when something newer even exists.
01-22-2020, 05:10 PM
Is the JVC DR-M10S still the go to? The how to on the site seems to imply that. And that many of the non JVC units don't have a true 3 hour mode.
http://www.digitalfaq.com/forum/vide...ipset-dvd.html
http://www.digitalfaq.com/forum/vide...c-chipset.html
01-22-2020, 06:43 PM
Yes, correct.
06-25-2020, 10:57 PM
What settings do you normally use on the DR-M10S?
06-26-2020, 06:36 AM
FR160 to FR180. This gives high bitrate to 352x480, looks as good or better than XP mode, same/better bitrate allocation.
End of Windows 7 support in January 2020 VideoTechMan General Discussion 2 07-26-2019 11:01 PM
Suitability of current production TBCs? ehbowen General Discussion 2 03-24-2018 02:20 PM
How do current consumer camcorders stack up against ones from the 90s and 80s? premiumcapture Videography: Cameras, TVs and Players 9 03-05-2014 10:12 AM
Current good DVD media in USA stores lordsmurf Blank Media 4 11-22-2005 04:18 PM
Current copying methods, as of Nov. 2005 admin Copy DVDs, Duplicate, Replicate 0 11-17-2005 03:41 PM
