06-13-2021, 12:00 PM
mbassiouny mbassiouny is offline
Hi,
I have 3 different JVC SVHS VCRs (with line TBC), but the three of them do not seem to offer the same quality of captures. I am trying to pick the best device out of the 3 to do my other captures.
I did some comparisons on my own, opened the videos in AVSpmod and compared some frames and picked one but I would like to hear a second opinion.
Do you guys mind giving your opinions on these captures.
I have attached 2 clips, each capped from the 3 devices, with TBC on and off.
for people who have experience with JVC decks: In addition to the question of which out of the 3 is better, how do my captures compare in general to what you would expect from a high-end JVC deck?
Setup: VCR-> Hauppauge live2 -> Virtual dub lossless capture.
Thanks in advance
06-13-2021, 02:16 PM
What are the models?
06-13-2021, 02:56 PM
I didn't mention them for 2 reasons:
- They're not US models, so I doubt people here would know them... but they were all made between 1999-2003, and the 3 have same functionalities.
- I was afraid users might be biased based on specs/model
I thought the comparaison is model-independent? so mentioning them would be irrelevant (I might be wrong ?), + who knows if any of these is not performing like it should... so for example if model X is generally better than model Y, there is still a possibility that my unit of model Y is not performing well/as intended... (that's what I think but feel free to correct me if I am wrong)
06-13-2021, 09:50 PM
I can look blindly at VCRs, but sometimes knowing the model helps me watch for known defects of the model. Blind advice from a tiny clip will be far more prone to errors, it's less scientific. A/B testing isn't good when both are unknown variables.
06-14-2021, 04:44 AM
timtape timtape is offline
Originally Posted by mbassiouny View Post
Hi,
I have 3 different JVC SVHS VCRs (with line TBC), but the three of them do not seem to offer the same quality of captures. I am trying to pick the best device out of the 3 to do my other captures...
Even if they were exactly the same make and model, with consecutive serial numbers, it's irrelevent now.
An otherwise excellent condition machine but with a dirty tape path or one small fault can make the audio and video playback terrible, even non existent. An inexpensive machine in top condition can run rings around it.
It comes down to each unit's condition right now at this moment. This is the last thing most people want to hear but sadly it's true.
The following users thank timtape for this useful post: mbassiouny (06-14-2021)
06-14-2021, 04:47 AM
I know, this is is exactly what I said in my reply number #3 http://www.digitalfaq.com/forum/vide...html#post78041 even if my vcr 1 is the best of the 3, the condition and age may make it worse than the 2 and 3 which are normally worse.
06-14-2021, 05:17 AM
Yes you did and I support what you said.
Help planning VHS capture project, best VCRs? BPHusker Project Planning, Workflows 21 11-29-2021 08:59 AM
Help choosing V-Dub Version for Capture and HQ filtering CarlEHL Capture, Record, Transfer 2 10-02-2020 07:51 PM
PAL VCRs and capture options? kreso05 Capture, Record, Transfer 6 12-30-2019 10:20 AM
VCRs, capture cards: Can this be done cheaper? Daegalus Capture, Record, Transfer 11 10-25-2016 03:07 AM
Top JVC VCRs to capture old VHS in the best quality ? Acden Capture, Record, Transfer 3 04-10-2012 01:01 PM
