02-02-2022, 11:27 AM
valthrudnir valthrudnir is offline
Hello!
Long time listener, first time caller. I was wondering if anyone has seen this issue with my current workflow:
Microsoft Windows XP Pro - Version 2002 SP3
Panasonic AG-1970 > Datavideo TBC-1000 > Pinnacle 710-USB Rev 1.0 > VirtualDub 1.9.11
The issue being that no matter what I seem to do I cannot get VirtualDub to acknowledge the video source from the 710-USB - composite or s-video.
I tested the 710-USB on another machine running Windows 10, following this thread and instructions provided by LS
http://www.digitalfaq.com/forum/vide...html#post64929
and everything works as expected - using Crossbar Thing workflow. So I am moderately confident that there are no issues with the 710-USB hardware wise as I was able to capture with no issues.
I am using the PCLEUSB2x32 driver provided by LS in the above mentioned thread and everything appears to be installed properly.
I am able to capture successfully with this machine (Windows XP) using an alternate capture device and this workflow:
Panasonic AG-1970 > Datavideo TBC-1000 > ATI TVWonder Capture > VirtualDub 1.9.11
But I would really prefer to use the 710-USB if at all possible.
Any help / assistance is greatly appreciated.
Thank You
02-02-2022, 07:02 PM
CaptainKirk CaptainKirk is offline
I would check Device Manager and see if any devices (Pinnacle in under sound/video) have a yellow exclamation mark on them. If this is the case, it's a driver issue.
SCRATCH the above. I just saw your provided screenshot of Device Manager.
02-03-2022, 03:10 PM
I had to use Crossbar Thing in XP to get the 710-USB to work.
Light sources in VHS whites out detail shane7951 Capture, Record, Transfer 4 09-06-2021 01:40 PM
First VHS capture (ATI 600 USB, WinXP), how to improve it? bluegrassdj Capture, Record, Transfer 2 03-06-2021 08:56 PM
How to capture and output old analog sources easily? MrEx Capture, Record, Transfer 12 09-01-2020 07:46 PM
MainConcept Settings for VHS Sources jrodefeld Encode, Convert for discs 12 11-09-2011 12:06 PM
