04-24-2025, 06:38 AM
AndreasAndersen AndreasAndersen is offline
My recording of an old VHS tape "stutters" (not sure what the exact term is) a lot when digitalizing.
I am using a Panasonic NV-HS860 (with in-line TBC enabled) -> VCAP800 USB (s-video/composite same problem) -> OBS/VirtualDub
Viewing the VHS tape on my TV works fine, and running the s-video output to a Sony HandyCam TRV240E works fine as well (viewing on HandyCam screen). But when running through the capture device the video stutters like the attached example.
Should I get another capture device like for example the Pinnacle 710 USB or perhaps IO-Data GV-USB2 or Hauppauge usb live 2. I am not looking for the best quality just something that doesn't stutter
Thanks in advance
File Type: mp4 491573747_9725902217456166_8766240011436811536_n.mp4 (4.58 MB, 5 downloads)
04-24-2025, 07:00 AM
themaster1 themaster1 is online now
Try to force the color system to PAL (if it's a pal tape) rather than AUTO, should be in the menu somewhere
The following users thank themaster1 for this useful post: AndreasAndersen (04-24-2025)
04-24-2025, 07:34 AM
I found the setting for "TV System" in the VCR and put it to PAL instead of AUTO but it doesn't really change anything.
(see attached picture)
04-24-2025, 01:36 PM
Try to connect your usb card to the best usb port. If it's a tower its on the back otherwise read the mobo manual
VHS recording in 2024? johnEtna Capture, Record, Transfer 18 06-15-2024 10:18 PM
Video stutters with lengthy captures? QueenAllTheWay Capture, Record, Transfer 1 07-13-2021 04:00 AM
Deinterlacing PAL footage stutters when frame rate doubled? juiceycow Restore, Filter, Improve Quality 6 02-25-2021 04:38 PM
Dual VHS recording in the 90s? dima Videography: Cameras, TVs and Players 12 03-09-2020 03:15 PM
Need a DVD Recorder for Recording VHS to DVD Konfusion Capture, Record, Transfer 8 04-11-2010 06:13 AM
