03-19-2026, 11:38 AM
rickpo12 rickpo12 is offline
I am looking for recommendations on what software to use to capture/record the videos that is coming from VHS/Hi8/MDV? Currently I have been using QuickTime, but have been questioning whether this will give me the best results. I also plan to post edit each video in Premiere Pro.
Thoughts and Recommendation on MacOS ?
Thank you
03-19-2026, 02:04 PM
What kind of capture method are you using? DV via FireWire? If so, use QuickTime 7.x Pro (registration code available online) and make sure the quality is set to "device native".
03-19-2026, 02:41 PM
vwestlife, thank you for your response. My method is:
VCR -> sony DVMC DA2 -> firewire > firewire-to-thunderbolt 2 -> thunderbolt2-to-USBC -> Macbook Pro
Thank you for the tip on device native, I will test this out.
Rick
Good USB video capture card with software? DaveVegas2024 Capture, Record, Transfer 14 09-17-2024 06:21 AM
Monitor recommended for post-capture video editing? sephi Computers 2 10-09-2022 03:23 AM
Video editing software recommended? flagada Edit Video, Audio 16 06-27-2022 03:41 PM
What software is recommended for DVD menus? soundquality Author, Make Menus, Slideshows, Burn 2 10-01-2013 10:25 AM
Advice on VHS capture setup (capture device, proc-amp, recommended connections) Simon76 Capture, Record, Transfer 12 12-23-2010 03:46 AM
