04-16-2021, 01:17 AM
We recently got another PAL deck.
It plays well enough. The alignment is probably off, but not the issue here.
When trying to REW or FF the tape, it does the usual slow-speed winding for a short burst. Then it makes that disengage noise, and high-speed winds.
This unit just makes a "whoom whoom whoom" noise instead of high-speed winding, then shuts off.
It also tried to eat a tape because the tape guides wouldn't get past the hump. A gentle nudge with a finger helped the guide move, and then ejected the tape. But I don't think this is related to the REW/FF issue. It may mean the transport motor is going as well.
My inclination is that it's a belt issue.
But we won't start taking it apart unless the seller gives his okay. Otherwise it'll be returned.
Your thoughts?
04-16-2021, 02:49 AM
The first thing to do in this case is clean the old grease and apply a fresh one to all sliding tracks, Replace the ff/rw capstan belt, It is recommended to clean the mode switch while in there.
Fast forward and rewind VHS before capturing? Padawan Capture, Record, Transfer 12 10-08-2018 11:11 AM
JVC BR-8600U won't play tape, fast forward, rewind? Dead Christmas Video Hardware Repair 2 05-07-2016 07:31 AM
MPEG ripped from DVD plays in fast forward ? admin Edit Video, Audio 0 07-24-2010 01:55 PM
Jvc gr-sxm515 plays with fast forward lines admin Capture, Record, Transfer 0 10-18-2009 03:32 PM
