10-18-2022, 03:33 PM
sawing14s sawing14s is offline
My current Panasonic DVD-VCR unit (a DMR-EZ47V) plays distorted audio on any tape I insert. It doesn't sound like the regular kind of hi-fi video distortion either - it's more like digital 16-bit white noise, plus some odd reverb or tape delay. This only applies to the VCR part of the unit; the DVD part is fine. I don't know how to get rid of it, but I'm guessing there must be a simple fix - recapping perhaps? I’ve already tried a head cleaner tape; it didn’t help. I also don’t have the original remote, but I got one that's compatible with that make and model. I've tried using it to change the audio output settings, but to no avail.
The unit was manufactured for the UK, which means I use a voltage adapter to plug it in and use it. It originally came with a SCART cable, which I don't use. Finally, whenever I connect another playback device to one of the RCA inputs, I get the same kind of audio distortion. I took it to R&B Electronics in Redwood City, but they couldn’t fix the issue.
https://streamable.com/id6xbk
This video is a comparison to show what it sounds like when I play a tape on the Panasonic VCR vs. the Sanyo VWM-710 NTSC VCR I use more often. I think it may have more to do with the circuitry than the video head itself, but I could be wrong. If anyone has any insight on this issue, feel free to share.
12-18-2022, 02:50 AM
Has anyone seen the video I posted? Can you tell the difference in playback?
12-18-2022, 06:11 AM
The issue is on both playback of a tape and feed-thru of audio?
Both HiFi and only normal sound tapes?
Be interesting to see the waveform of a pure audio tone.
12-18-2022, 02:08 PM
It depends where that audio distortion resides, If it's in the line level audio out preamp then it's most likely some bad capacitors, if it's in the processing chip an oscilloscope is required to troubleshoot this problem, If you have the skills to do it try to inspect the audio out preamp capacitors and test their ESR and replace if necessary otherwise there is nothing we can do over a public forum.
12-18-2022, 03:07 PM
Could you post in this forum a .WAV file of the audio only? Maybe two files, one for each VCR?
ntsc\pal, panasonic dmr-ez47v, vhs capturing
Panasonic NV-SV121, no line TBC on unit? Zerowalker Restore, Filter, Improve Quality 22 05-21-2018 03:17 AM
VHS audio issue Y4BB Restore, Filter, Improve Quality 1 05-20-2018 08:28 AM
Panasonic AG-1980 audio issue - where did it go? talonhead Video Hardware Repair 19 02-04-2018 08:46 AM
JVC HR-S7600U audio issue volksjager Capture, Record, Transfer 2 04-29-2012 10:41 AM
For Sale: Panasonic AG-1980 VCR, broken but maybe fixable TBC, Proc Amp, & more *Bix* Marketplace 3 03-11-2011 05:08 PM
