05-23-2023, 05:02 AM
Hey all,
I have a Viltrox monitor that needs a power supply.
It is a DC-90 HD monitor, of which I have 2 of them, the PS I have works for both, so I have attached photos of the plug and monitor.
I'm no good at determining the various symbols on the plug and what they mean, so...
If someone could locate such a plug on Amazon (or wherever) link me, I would be eternally grateful.
Thanks everyone.
05-23-2023, 11:44 AM
The item needs power within 8 volts to 18 volts. (Wow, wide range!)
With 2 amps minimum.
Center-positive. Most items are center-positive. The C opens to +
Standard 2.1/2.5 tip.
The battery has even lower needs, weird. Just under 8 volts, and 5 watts is just under 1 amp.
I would suggest you get a standard quality APD here, 12V 1A, center positive, both standard tips.
Buy this unit, $8 shipped, from this seller: https://www.ebay.com/itm/201547508933
05-23-2023, 01:12 PM
BW37 BW37 is offline
Just a guess but the extra power requirement for the AC adapter vs battery is to allow charging of the battery while the monitor is in use and battery attached???
Thus 12V/1 amp adapter will be adequate for powering monitor only but might you might want 1.5 - 2 amps if batteries are to be used/charged on the monitor.
5.5mm x 2.5mm plug or 5.5mm x 2.1mm plug unknown is resolved via the dongle included in LS's recommended purchase.
My
BW
05-23-2023, 01:50 PM
Good call!
Yep, that's probably it.
monitor, plug, viltrox
Videonics MX-1 has no power supply? 0014x Capture, Record, Transfer 3 03-22-2021 09:31 PM
VCR has problems with power supply? dima Video Hardware Repair 7 03-18-2021 01:23 PM
Where to find power supply for JVC HR-D970U? Apache2223 Video Hardware Repair 0 02-04-2020 05:34 PM
About the VideoData DAC-100 and power supply jeffpeck General Discussion 0 11-11-2019 12:44 PM
RCA DRC8335 DVD/VCR combo power supply is hot rumburaski Video Hardware Repair 2 06-13-2013 06:15 PM
