06-12-2023, 05:59 PM
SaikoSabrina SaikoSabrina is offline
Hi!. I was trying to play some tapes on my Samsung DVD-V2000 when the tapes would be stuck on "STOP" and then eventually Eject. I took off the metal cover to demonstrate what happens to the tape inside of the VCR. (Attached below). I'm not sure how to diagnose or repair the VCR. Anything helps ^^
06-12-2023, 07:04 PM
The first thing you do is look inside to see any broken, cracked or missing components, check for foreign objects, remove the deck and remove and clean the mode switch and go from there.
The following users thank latreche34 for this useful post: SaikoSabrina (06-12-2023)
06-14-2023, 11:17 PM
Hi all, let you know that what I was experiencing was caused by the head drum not spinning (this can be seen in the video). For some reason, it was stuck, so I wiggled it enough to allow it to spin, and voila! problem solved! Hope this helps anyone experiencing similar issue.
samsung, vcr, vhs
JVC HR-S7600U ejects tape after 15 seconds? originalsboy11 Project Planning, Workflows 5 12-26-2020 02:19 AM
SL-HF900 ejects tape right after insert emamid Video Hardware Repair 9 04-04-2019 03:32 PM
Panasonic AG-1980P ejects, refuses to play? [VIDEO] lordsmurf Video Hardware Repair 9 02-18-2017 07:27 PM
Panasonic AG-1980 won't play tape, just ejects it? syrist Video Hardware Repair 3 11-23-2016 09:17 AM
VCR ejects mangled tape? Dead Christmas Video Hardware Repair 12 04-25-2016 09:35 PM
