07-22-2023, 09:16 AM
Mr_Bear_ Mr_Bear_ is offline
My LG BC983W vcr seems to be stuck in a "Safe" mode, or probably child lock mode.
The only way I can turn the vcr on is by putting a tape inside and pressing play, which doesn't play the vcr but sends the VCRs signal to the tv. The only function that seems to work is the eject button, as none of the other front buttons seem to work, not even the power which I have to switch off at the wall plug in order to turn it off.
I don't currently have a remote for the VCR, is there a way I can turn off this mode without a remote?
I found a remote on eBay with a similar model number, is there a way I can connect / pair the remote to my VCR?
I don't have a copy of the user or service manuals for the VCR, and haven't been able to find one online.
I'm hoping someone has a copy they are willing to share.
07-22-2023, 09:33 AM
A lot of these low-end decks are worth fix, and not suggested for using even when perfectly "working".
If it's a deck feature, and the control is only on the remote, then you probably have to track one down.
Many times, a "similar" deck isn't as similar as you think, the remote will not work, parts internal are not shared (or even related).
A lot of these consumer VHS VCRs never had service manuals, as it was disposable e-waste when it stopped working. Repair was never intended. Just toss it, buy another.
07-22-2023, 10:33 AM
You can turn it off with a button on the remote. You don't need the exact one afaik, at least all my LG remotes seem cross-compatible with all my LG made decks, even with the ones that have different brands on them (other than possibly the RCT689 VCR/dvd-recorder combo). I have one that looks exactly like the model named just with a different brand/model number and both the remote for my LG V290 DVD/VCR combo and my older 2 head LG works on it. It might be possible to turn off with a button combo but couldn't find something that worked without the remote last time I tried on another LG that was locked.
Panasonic NV-FS200 HQ, stuck in eject mode? Thierry Henry Video Hardware Repair 1 08-14-2020 06:25 AM
Hi8 Tape stuck - Is there any way to fix this? DeeSeven Capture, Record, Transfer 5 04-23-2014 04:42 PM
Is SP MODE the Best DVD Recorder Mode? (NO!) lordsmurf Capture, Record, Transfer 4 04-14-2013 10:01 PM
Panasonic FR mode or samsung 4 hr mode for vhs to dvd cyber-junkie Restore, Filter, Improve Quality 5 02-24-2010 10:29 PM
Encoding an XP (1 Hour Mode) MPEG to SP Mode shadowkaos Encode, Convert for discs 2 10-30-2007 09:29 AM
