04-14-2025, 09:11 PM
7imeb0mb7immy 7imeb0mb7immy is offline
I have had a Feral Industries C-100 TBC / Frame Sync (Release 4.0 circa 1992) since 2019. Had a good run with it during the pandemic, got married, moved houses, finally got around to getting back to the list of family tapes to digitize. Now I can't seem to get any output from it on both composite and svideo.
I only have a multimeter and a universal counter as diagnostic tools, and just enough knowledge of basic electrical / electronics to get around. Since there is next to no information on this model out there I figured I'd hit the test points on the mainboard and post them, hopefully for comparison if someone else out there has one. Attached is a photo of the mainboard.
I will edit this to clean up formatting once I figure that out (I'm open to suggestions).
Test Point Approx. Readouts
TP1: .099 VDC
TP2: 000 VDC  54 MHz
TP3: 2.37 VDC  6.5 MHz
TP4: 000 VDC  60 MHz
TP5: 2.29 VDC  6-66 MHz
TP6: 000 VDC  55 MHz
TP7: 5.69 VDC
TP8: 000 VDC  60 MHz
TP9: 3.78 VDC  50-60 MHz
TP10: 6.41 VDC
TP11: 2.07 VDC
TP12: 4.68 VDC
TP13: .500 VDC
TP14: .540 VDC
TP15: ---
TP16: 000 VDC  41 MHz
TP17: 3.48 VDC
TP18: ---
TP19: 1.40 VDC
TP20: 000 VDC  7 MHz
DIP Switch and Jumper settings
SW1: 1:On; 2-4: Off
SW2: 1-8: Off
JP1: Pins 1-2 jumped; Pin 3 empty
JP2: Pins 1-3 empty
Quite obviously I'm not getting any readings on TP15 and TP18.
PSU: +5 VDC and +12 VDC are good, -12 VDC seems to only be -2 VDC compared to ground but -12 VDC compared to +12 VDC (though my understanding of 'negative' voltage is limited).
All but one oscillator seems to read accurately with the universal counter.
I am willing to attempt replacement of the 'bad' oscillator, as I have replaced similar components on PC mainboards in the past. Any suggestions, questions, guidance?
Thanks in advance.
Tim
Last edited by 7imeb0mb7immy; 04-14-2025 at 09:17 PM. Reason: Incorrect voltage on PSU.
c-100, feral, tbc
How to test if signal at any point is 4:1:1 subsampled in a chain? aramkolt Capture, Record, Transfer 1 08-12-2023 06:13 PM
Feral Industries A-422 TBC bad output? zinkatres Video Hardware Repair 9 10-22-2022 04:19 PM
Feral E-422 (E-4:2:2) Series TBC/Synchronizer Operation Manual Yodigity Video Hardware Repair 1 02-10-2019 08:57 PM
Feral A 4:2:2 TBC ... thoughts? VideoTechMan Restore, Filter, Improve Quality 5 06-18-2012 02:18 AM
