09-17-2020, 09:47 AM
rcanpolat rcanpolat is offline
Hi folks,
First time poster and i am having some trouble. Please bare with me if some of my terminology is incorrect. I'm trying to convert some old VHS tapes to digital via a PCI capture card.
I've bought a Avermedia CE310B PCI card, brand new device, just arrived today installed into a brand new PC.
When i try play back video from the VHS player to the PC i get no audio and no sound.
My VHS player is a Sony SLV-SE7401 & its inputs and outputs are as follows:
  • Output: Scart Line 1 (black color labelled euro AV)
  • Output: Scart Line 2 (blue color)
  • Output: Audio out (L+R red+white)
  • Output: TV Out (RF)
  • Input: Antenna Input
I've tried using a Male to Male RCA cable into a RCA to Scart adapter. The scart plugged into the VHS and the RCA into the capture card. I've changed around the resolution and swapped around from Composite to S-Video and back again (just to cycle the input) and i get no video and no audio output. I've tried both scart outputs on the VHS. The screen output either remains blue or black (depending on what resolution i set the capture to).
I tried another cable, gold plated JVC dedicated Scart to RCA and the same result as above.
When i plug in the RCA cables audio (white and red) into the VCR's "Audio Out" port i can hear sound through my PC's speakers.
I then tried an old TV Out (RF) to RCA cable (i think that is what it is, i used to use it on my old Super Nintendo) and i still can't get any audio or video out.
I'm not using any copy protected tapes, they are old family VHS tapes from 20-30 years ago. I know the VHS player works because it outputs over scart to a TV just fine and plays the tapes perfectly with audio and video.
Do i need to have it plugged into a TV to get an output to a PC as well or what am i doing wrong here?
Any help would be very greatly appreciated.
09-17-2020, 10:46 AM
Does your scart adapter have a switch on it? Out and in are not the same pins on the scart port, and most adapter that don't have a switch on them are input only.
09-17-2020, 10:56 AM
No switch.
The scart adapter i have is labelled "Microsoft". I think it belongs to an old xbox console so it is more then likely belonging to the TV side.
The JVC scart cable i have would be the same idea, the scart end always ended up on the TV because the RCA side went to a camcorder.
Thanks for the tip, I completely forgot some of the scart adapters had switches on them
I'll post back an update when i find a switchable adapter.
I'm going to mark this as solved. I purchased a scart adapter with a switch for Input/Output and its done the trick. Audio and Video working perfectly.
The following users thank rcanpolat for this useful post: lordsmurf (12-25-2020)
12-25-2020, 04:42 AM
Subarit Subarit is offline
This is very good when people report resolved problems.
The following users thank Subarit for this useful post: lordsmurf (12-25-2020)
avermedia, digital, vhs
Unable to change output to 720x480 - Osprey card issue? kriscraigs Capture, Record, Transfer 2 01-28-2019 04:26 PM
AVerMedia Live Gamer HD crash, only on YouTube videos? yerp Capture, Record, Transfer 1 09-23-2017 03:17 AM
Avermedia Game capture Hd not capturing from medical device. axicraw Encode, Convert for streaming 0 04-29-2016 04:30 AM
AverMedia C027 HD DVR & MainConcept Encoder 1.4 for capturing ? rlschoemer Capture, Record, Transfer 4 02-01-2012 01:53 PM
