04-30-2022, 09:27 AM
Barthburger Barthburger is offline
Using this for VCR transfer. It has worked previously but now is just omitting B&W. Tried different cables, VCR, monitors, etc. It's definitely the device. Even the "color bars" when no input/out is plugged in is in B&W! Any ideas on how to fix this?
04-30-2022, 09:53 AM
Did you make the mistake of getting the flawed black AVT-8710?
04-30-2022, 09:55 AM
There are others? It was the only one available when I bought it a few years ago.
04-30-2022, 10:00 AM
timtape timtape is offline
I bought a black one new about 10 years ago. Worked fine until a few months ago when the picture became unreliable. The problem was two tired capacitors. Replaced them, now working fine.
The following users thank timtape for this useful post: RobustReviews (04-30-2022)
04-30-2022, 10:33 AM
Sounds very much like a component failure - like TimTape has pointed out. It's almost certainly fixable, but that will depend on your skills and willingness.
If you plug the machine straight into a monitor is it still displaying in monochrome?
04-30-2022, 11:35 AM
All black units are confirmed bad: http://www.digitalfaq.com/forum/vcr-...-8710-doa.html
100% of them.
All sort of flaws, reduced quality components from the original version.
The green units are 99% good.
Did my AVT-8710 die? msgohan Restore, Filter, Improve Quality 15 02-20-2025 02:37 AM
CTB-100 / AVT-8710 SDI mod? Mischa Project Planning, Workflows 4 01-06-2021 01:42 PM
Outputting VHS conversions for DVD and LCD TV discmeister Edit Video, Audio 3 10-09-2018 02:03 AM
AVT-8710 TBC actually doing it's job? Jtm732 Capture, Record, Transfer 0 02-12-2018 01:21 PM
Captured PAL VHS - Outputting to DVD - What Resolution Should I use? BayAreaSean Encode, Convert for discs 4 04-29-2016 11:13 AM
