05-15-2024, 12:10 PM
badonica badonica is offline
Which version of Hybrid works with Win7 32 bit?
Cheers
05-17-2024, 04:47 AM
Why using x86 version of Win7, and not x64?
05-17-2024, 05:35 AM
Thanks for the reply
It was the only version of Windows 7 I have on disc
05-17-2024, 08:08 AM
Installed Win 7 / 64 bit,
Installed Hybrid - tried to run it then got error message
The procedure entry point “CreateDXGIFactory2” could not be located
in the dynamic link library dxgi.dll
Any ideas?
Cheers
05-17-2024, 09:08 AM
The last Hybrid that works in 7 is 2020.12.13.1
05-17-2024, 10:51 AM
Hi,
Thanks for the info 👍🍀
Best Windows OS for Hybrid, Avisynth, QTGMC? aramkolt Restore, Filter, Improve Quality 12 03-15-2024 08:44 PM
Windows 10 works for video capture? Gary34 Capture, Record, Transfer 8 05-24-2023 06:40 PM
ATI All-in-Wonder 9600XT and Windows 7 works! NJRoadfan Capture, Record, Transfer 7 11-16-2020 01:00 AM
Which Windows works better for FireWire transfers? bfollowell Capture, Record, Transfer 20 02-13-2018 08:09 PM
AIW x1900 or AIW x1800, which ATI card works in Windows 7? zack82 Project Planning, Workflows 4 12-13-2016 08:19 AM
