12-13-2024, 07:59 PM
heychrischin heychrischin is offline
Am setting up with the “weak TBC” workflow:
VCR (S-Video with line TBC features turned off) -> DMR-ES15 (S-Video output) -> DVK-100 (S-Video output) -> Capture card
Should audio be sent from the VCR to the DMR-ES15 along with the video (before going to the capture card) or should audio go straight from the VCR to the card?
I suspect the answer is "Yes", because you'd want audio sync'd as much as possible.
12-13-2024, 09:28 PM
Aya_Rei Aya_Rei is online now
From my understanding it is best to route the audio through the es15 before the capture card because there would be an audio dealy of around 200 to 250 miliseconds, due to the es15 adding a video delay, and the audio not being affected if it isn't plugged into the es15
12-14-2024, 10:36 AM
fafeco fafeco is offline
Beware of the possibility that the audio path inside the Panasonic DMR-ES15 may be degraded. There are reported cases where one or both stereo channels are not working, due to the partial failure of the video+audio switching IC inside the Panasonic, which is really prone to electrostatic discharge damage. I would make sure that it works correctly before starting any serious capture work. Of course, if you bypass the audio section of the Panasonic you will have to take into account the internal delay of the video passthrough in the Panasonic, as Aya_Rei commented. For Panasonic PAL this delay has been stablished to be 120 ms (german forum link), but I do not know the value for the NTSC ones.
The following users thank fafeco for this useful post: lordsmurf (12-20-2024)
12-14-2024, 10:51 AM
Good to know, @fafeco. I will definitely be aware of that if audio is garbled/missing.
Since the video will also be being pushed through the DVK-100, should I account for a delay with that device as well?
12-20-2024, 10:34 PM
DVK does not process audio like ES10/15, so no. DVK has standard 1-frame (33ms) delay, not ~200ms like ES10/15. Huge difference.
audio capture, dmr-es15, dvk-100
Dropped frames, ES15, and audio sync? ThumperStrauss Capture, Record, Transfer 4 05-10-2024 01:38 AM
DMR-ES15 (PAL) s-video or SCART? contrast Project Planning, Workflows 5 03-21-2024 04:35 PM
Passthrough on component video out, Panasonic DMR ES15? guyburns Capture, Record, Transfer 5 03-02-2024 06:36 PM
Send VCR audio through ES15 and/or DVK? DigiTime12 Capture, Record, Transfer 4 09-15-2023 02:16 AM
Any drawbacks to passing audio through ES15 as well? EmielBoss Capture, Record, Transfer 0 03-28-2021 01:22 PM
