03-24-2026, 03:43 AM
Hotglove Hotglove is offline
Hi all, this is my first post, I have a 2019 16” Macbook Pro Intel 2.4 Ghz 8-core i9 running Sequoia.
I also have a Toshiba VCR and numerous tapes, a couple of VHS C tapes and a Sony Hi8 camcorder with a few tapes. I have connected this kit to an elderly Panasonic plasma TV and all is working correctly.
I wanted to convert all the tapes to digital and did a bit of research (not enough!) and have ordered a Blackmagic Intensity Extreme capture card from ebay for £30 (due to arrive in a couple of days)
However, a bit of trawling through sites like this forum suggests that the card will not work with Sequoia.
I already had a thunderbolt cable and adapter from previous kit.
I also have a Macbook Air that has been replaced because its battery was US, but works fine when connected to charger, I would be happy to change the MacOS on this machine if necessary (not sure which version it currently runs)
I suppose the worst case scenario would be to just sell on the card at about the same price, then think again about the VHS transfer.
All input welcome.
Blackmagic Intensity only capturing audio in VirtualDub? xdac Capture, Record, Transfer 7 09-10-2025 05:15 PM
Blackmagic Intensity Pro 4k good? Uraz88 Capture, Record, Transfer 19 04-04-2021 07:02 PM
S-VHS-C digitization project with Blackmagic Intensity? vin97 Restore, Filter, Improve Quality 35 03-03-2016 09:51 PM
Black Magic Intensity Extreme - capture uncompressed SD video? rigama61 Capture, Record, Transfer 16 08-14-2013 01:41 PM
Blackmagic Intensity Pro Flicker Problem P4RL Capture, Record, Transfer 6 05-25-2012 11:05 PM
