02-02-2012, 08:13 PM
i was capturing a tape today and all of a sudden the picture tuned black&white
the switch was on color - i flipped it to B&W and back to color and the picture returned to color
this happen 3 more times - i had to abandon the capture
has anyone seen this? could the switch just be bad?
this VCR has performed flawlessly prior to this
02-06-2012, 08:49 PM
I've seen this. Eventually the VCR would only play tapes as B&W. Something may be going out on it.
Forum user deter could write a novel on AG-1980 problems.
02-18-2012, 03:13 PM
deter's Avatar
deter deter is offline
Yep you have bad caps in this unit they need to be replaced. The machine may work fine, or you think it is working fine, however your color channels are going to be a mess, and everytime you press stop on a tape and re-start, you are going to have different shades of colors or color shifting...
Good luck...
Don't try getting around this, you CAN'T...
Next you take the VCR to your local shop, they replace 5 caps and charge you $75 or whatever. You get the machine back and you still have the same problems. That is the problem, nobody knows how to repair these things. I pulled my hair out doing this, but I figured it out. At the same time, it costs too much for you to ship me the unit and to ship it back, than to do the repairs...Just buy another unit....You can't cause you are going to have the same problems.....These units are 15 or whatever years old, lots of use, they go bad...
Weird problem with DVD Workshop Superstar Author, Make Menus, Slideshows, Burn 3 09-17-2011 10:24 PM
DV color space harmful to analog color quality? Verify? DeXeSs Capture, Record, Transfer 6 06-27-2010 01:48 AM
Weird audio problem Superstar Restore, Filter, Improve Quality 30 01-29-2010 09:20 PM
TDK discs are Ritek, time to switch? admin Blank Media 0 12-01-2009 07:37 PM
Weird DVD+R blank discs purchased in Europe admin Blank Media 0 10-18-2009 03:25 PM
