04-25-2015, 10:14 PM
Figured I would share that I purchased an EH59 from BHPhoto recently and on passthrough it fixes flagging. It has an excellent comb filter that is optional and fixes flagging. DNR can be turned on or off, and it works pretty decently but I like to denoise in software. Figured I would share!
04-25-2015, 11:29 PM
Panasonic DNR is notoriously smeary, so I'd be surprised if this unit was any better.
Having more options for passthrough decks as always nice.
I guess that's something else I need to update. What do you think -- should it be added to the TBC thread? I think so.
After years of trying, I've finally defined all TBCs (and "TBCs").
This would be one of the weaker special-use types.
04-26-2015, 10:53 AM
Thanks for the info.
The manual states that it's only optional for PAL content. (Comb filters for PAL operate quite differently.) I assume choosing "Off" changes it from 3D to 2D mode, since literally disabling the comb filter would be a very bad thing.
Comb Filter
Select the picture sharpness when recording.
The setting is fixed with “On” if you set “TV System” to “NTSC”
(> [Page] 66).
[On]     Pictures become clear and vivid. Normally, use this setting.
[Off]    Select it when recording noisy pictures.
I'm going to PM you a question I've been trying to get answered about these PAL units.
04-26-2015, 11:11 PM
No, don't PM! I like to read these sorts of conversations.
04-26-2015, 11:45 PM
After he did some measuring, it appears the EH59 has two blanking lines at the top of the image and the blacks are slightly elevated for HDD/DVD recordings (not sure if that means brighter or darker). Comparing to how the tape I used with it played without it, I was happy with how it performed.
Using TBC and video still tearing? jriker1 Restore, Filter, Improve Quality 127 10-06-2016 11:41 AM
Top Screen Tearing/Distortion GreenAcres Capture, Record, Transfer 6 02-15-2014 01:29 PM
VHS tearing even WITH TBC and JVC SVHS player. ramrod Restore, Filter, Improve Quality 2 07-13-2010 02:55 PM
Fixing VHS tearing during capture; JVC D-VHS vs. JVC S-VHS VCR? lucgallant Capture, Record, Transfer 10 05-09-2010 07:15 PM
VHS tearing - hardware to fix it? admin Restore, Filter, Improve Quality 2 10-01-2009 05:30 AM
