08-06-2016, 01:02 PM
qiko qiko is offline
So I decided to upgrade to the free W10 OS, and reinstalling all my capture applications. I am trying to figure out which drivers to install.
Should I go with Vista 64-bit Install\Vista\Bin64\Setup.exe ?
or Driver Update from diamondmm.com, VISTA® 32/VISTA® 64 DRIVER VER 22 (2008-08-05) ?
Is the ATI Catalyst Media Center required ? It failed to install properly in Windows 10 during installation . I don't recall ever using this app before when capturing with VirtualDub.
Or anyone already managed to get theirs working in W10?
Thanks,
08-06-2016, 01:09 PM
Try the Vista 64-bit drivers first.
No, you don't have to install CMC if you're only going to use VirtualDub.
08-13-2016, 07:52 PM
CEDmarshal CEDmarshal is offline
I set one up on Windows 10 a little over a week ago. I used the 64-bit Vista drivers from here:
http://www.diamondmm.com/tvw600usb-a...er-hd-600.html
The only thing of note was that I was careful to install the drivers prior to connecting the capture stick the first time. I don't remember if it required a reboot after the driver install. (If it asked to, I would have).
After that, I plugged it in and VirtualDub found it immediately.
The following users thank CEDmarshal for this useful post: lordsmurf (08-14-2016)
08-15-2016, 01:27 PM
thx, I installed VISTA® 64 DRIVER VER 22 (2008-08-05) even though I had AMD Catalyst Control for my radeon card. It was able to recognize the latest drivers and only installed the missing files.
08-29-2016, 03:12 AM
bilbofett bilbofett is offline
I got ATI 600 USB (scored a BRAND NEW Visiontek) working *GREAT* in Win10 x64!! (and used your drivers!)
Thank you!!
02-20-2019, 08:20 AM
rflagler rflagler is offline
For anyone trying to find these drivers. The webpage on diamond's site is gone, but the URL to download the drivers is still valid.
http://www.dmmdownload.com/downloads..._XP_VER_22.zip
I'm also attaching them to this post.
File Type: zip TV_WONDER_600_USB_DRIVERS_XP_VER_22.zip (19.14 MB, 128 downloads)
The following users thank rflagler for this useful post: DC70 (08-13-2020), sanlyn (02-20-2019)
02-22-2019, 03:52 PM
ragu0012 ragu0012 is offline
Thank you for all this. I'm getting Windows 10 this week. (Win7 isn't compatible with a lot of newer processors, i'm learning.)
ATI 600 USB won't install on Windows 7 system? AndyO6322 Capture, Record, Transfer 20 10-21-2019 01:13 PM
BuyVM user KVM? How do I install Windows? via Email or PM Web Hosting 1 07-25-2013 07:22 PM
Problem with laptop, cannot install Windows XP? ECruzDigital Computers 3 01-31-2013 11:27 PM
Best drivers for ATI All In Wonder Radeon, Windows XP install? peter5on Capture, Record, Transfer 14 08-14-2012 01:51 PM
Can you help? Disc jams when trying to install Windows d.smyth Computers 15 08-10-2005 03:18 PM
