04-29-2016, 09:24 AM
BayAreaSean BayAreaSean is offline
So this is probably a pretty easy question for many, but the resolution switch between regions/DVD PLayers has always confused me. I was given a PAL VHS tape that I capture in Premiere Pro 5 with PAL DV Codec. I'm planning on exporting to Encore to make a DVD that will be region free but play in North America. Should I keep the PAL resolution, or export it into media encoder as 720x480? Thanks in advance.
04-29-2016, 10:30 AM
720x480. VHS is interlaced. So is NTSC DVD, and so is PAL DVD. Never resize video while it's interlaced. Deinterlace first, then resize, then re-interlace. NTSC DVD is 29.97fps, not 25fps. If the PAL DVD is movie-based, it could have been made in a number of ways. We'd need a short sample. There are ways to do that in Avisynth and some other free apps without screwing up frames and motion, but I don't think you'll fall in love with Premiere's results. Let us know how it turns out.
I don't work with analog to DV captures, but others can give you some ideas if you want to submit a short DV sample of a few seconds (with motion of some kind) to see how it can be done.
DVD specs for PAL & NTSC: http://www.videohelp.com/dvd#tech
The following users thank sanlyn for this useful post: BayAreaSean (04-29-2016)
04-29-2016, 10:45 AM
So when exporting out of Premiere should I change res from PAL res to 720x480 or would it make more sense to change settings to 720x480 when creating a new Encore project? I guess testing both ways would be a good way to see the results
04-29-2016, 11:11 AM
Either way.
04-29-2016, 11:13 AM
Thank you!
ntsc pal dvd, pal, resolution
Advice on captured VHS, faulty s-video? zack82 Restore, Filter, Improve Quality 2 04-26-2016 09:26 AM
ATI MMC Captured file location rocko Capture, Record, Transfer 0 06-22-2015 11:58 AM
Mistakenly captured into MS-YUV 16 bit metaleonid Restore, Filter, Improve Quality 6 01-27-2015 03:46 PM
No Audio Captured yargellham Capture, Record, Transfer 7 01-11-2005 01:53 PM
ATI video captured ... now what ? bigroy Capture, Record, Transfer 1 04-28-2004 03:52 AM
