07-16-2019, 11:20 AM
waloshin waloshin is offline
I must combine mulltiple short films to a bluray for an upcoming film festival. Typically the videos are 1080p 24 abd 23.97 some sre 25 fps. What is the quickest and most affordable software to encode them as bluray i do not need any menu.
09-25-2019, 09:29 AM
SPiel SPiel is offline
Recommend using Movavi Video Converter, it supports every video format out there, so there should be no quality loss thanks to its encoding algorithms. You can grab it here https://www.movavi.com/videoconverter/
09-25-2019, 09:41 AM
Thank you I ended u going with Tmpgenc authoring works 6 which worked great especially with the batch processing.
09-27-2019, 09:37 AM
You're welcome!
8mm films capture advice, best transfer method? Buio Capture, Record, Transfer 8 05-25-2017 04:26 AM
Out of luck with multiple JVC HR-S9500 MadMovieBuff Video Hardware Repair 9 10-28-2016 04:17 AM
Commercial transfer of old 8mm and Super8 films to digital format ? echenberg Capture, Record, Transfer 1 05-17-2012 02:27 PM
Opinion on the CopiAll device? Want to backup films... lordsmurf Capture, Record, Transfer 2 04-15-2012 10:06 PM
Splitting across multiple DVD’s fidel1962 Copy DVDs, Duplicate, Replicate 1 07-18-2005 05:31 AM
